Question about Watches
I don"t know how to calibrate or set up the compass function. Please advise.Its for a casio pro trex sports watch.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
Write down the four-digit module number from the watch back, and go to this link for full info in PDF format:
http://world.casio.com/wat/download/en/manual/
Good luck, Bill
Posted on Sep 01, 2010
Pro trek 3500 compass only going up 300 degrees. Doesn't reach 360 north???
THe PRO-TREK watch compass is very sensitive to nearby Iron (eg. cars, fridges, steamships, artillary canons, battering rams, guillotines, etc) and anything wearable or embedded in your body. I had to calibrate mine in the middle of a baseball field.
Aug 09, 2017 | Casio Digital Compass Twin Sensor Sport...
I just bought the Casio SGW500H-2B Mens Twin Sensor 100M Digital Sports Watch Compass Thermometer. My problem is the digital readout in compass mode reads fine but the needle/ second hand points to east...
To fix this, hold down the A button for 4 seconds. this allows you to recalibrate the home position of the second hand. My secondo hand was posting exactly 90 degrees west in compass mode, and this home position recalibration fixed it 100 percent.
Sep 11, 2013 | Casio Watches
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
Just got my husband a casio pro trek sgw100-1 - we calibrated the compass but east and west are switched - north and south are fine - any ideas? thx
As a pure shot in the dark, are you sure that you calibrated it so that it was pointing to the north when it should be and not to south?
If it was pointing south instead of north, then East and West would be reversed.
Sounds a bit daft but better than the directions of east and west changing?
Check your calibration perhaps?
Nov 29, 2010 | Casio Watches
Hi, I have a casio protrek PRG-80T-7V(triple sensor). I haven't experienced any problems with it until recently. When I traveled abroad i passed through the ray gate in the airport wearing my watch....
Try to reset the watch.But first be sure that you capable of doing this.
Reseting the watch procedure:
1)Remove the back cover.Be sure that you have the appropriate screwdriver.Keep the 4 screws safe, not to loose them.
2)On the chassis of the watch (metallic surface) somewhere there is a hole with AC (All Clear) written nearby.
3)Use one little thin retracted paper clip (not totally retracted).Insert the retracted end of the clip into the hole, gently, until it touches the end and with the upper part of the clip contact the chassis (metallic surface). Wait for 1-2 sec and remove the clip gently.The watch is now reset.All functions have been set to factory settings.
4)Put back in place and with caution the back cover, respecting right (up-down) positioning and taking care that the O-ring gasket is well in place,first.
5)Holding in place with one finger the back cover,screw back screws gently and without applying excessive force (delicate job) until you meet resistance, in the following order:
Up-right,down-left,up-left,down-right.
After setting the time/day/date etc try to calibrate compass both ways as you did before.
I hope this will solve your problem.
NOTE:Again,be absolutely sure that you are capable of doing this.
It is a bit delicate job.If not,you better bring the watch to an official CASIO service center.
Apr 27, 2017 | Casio Protrek Triple Sensor PRG70 1BVDR...
How to set the compass on a casio SGW 100
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Casio Digital Compass Twin Sensor Sport...
I lost my owner's manual for my Casio SGW-100B. When I try to use the compass it asks me to please calibrate
Above link no longer valid. Here's the current one:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3157.pdf
Also, the key was inputting the correct #, in this case 3157 - NOT the 100B - at the following page:
I had almost given up when I looked again at the back of my watch and found the other number.
Sep 16, 2009 | Casio SGW100B-3V Watch
Casio Pathfinder Digital Compass will not calibrate
http://pathfinder.casio.com/support/manual/
find your watch and use the manual. if there is no solution then take it in for repair. any Casio retailer should have repair center information.
Jan 25, 2009 | Casio PRG-40T-7 Pathfinder
Watches Logo
198 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
