Question about Garden
Mower blowing white then black smoke & running rough
  • 252 Answers
If unit is ohv engine - i gather unit is using oil ?
may have a blown head gasket and air filter may be oil / petrol soaked
restrcting air flow
check oil level is correct ( and does not smell of petrol ) wet sumped and breather is working ( not stuck closed )
check for tight valve clearance
if all these are ok then might suspect worn rings / bore ?
may need further info on engine model - type
let me know and i will try help more if can
cheers
Posted on Aug 08, 2010
Mower will start but blows lots of white smoke and dies when throttle is moved to full
sounds like to much oil but you say the oil level is fine. you may want to check the compression on the head to see if the head gasket is blown. if there is a lot of smoke or oil blowing out the oil tube, that is a sign of blown head gasket.
Nov 27, 2017 | Ariens Garden
Powermore 173cc OHV - suddenly running rough burning twice as much fuel as before. Blowing black smoke out of the exhaust. Is there a float that might be stuck open?
It.sounds like you have a hole in the float. If the float was.stuck, the oil would be filled with gasoline. With a hole in the float, the engine would flood, blow black smoke and run rough. Remember, black smoke is fuel, white smoke is water, and blue smoke is oil. Hope I helped.
Sep 04, 2013 | Garden
A 450 series 148cc on a victor, mower starts but runs rough(low engine rev and blows black smoke)
There has been a great deal of issues with the diapham between the carb and the tank, replace it and hopfully all will be well again.
Mar 10, 2013 | Briggs & Stratton Garden
4g63 delica black smoke running rough
You have a failed head gasket
Major repair
Hope you didn't think the stop leak was
a genie in a bottle,never need any product
in any vehicle,just the proper repair
White smoke was coolant ,should have known that
Nov 24, 2012 | 1996 Mitsubishi Eclipse
91 cressida running rough also blowing smoke nothing wrong with head gasket any clues??
white smoke would be a sign of a head gasket blue smoke is a sign of burning oil black smoke is a sign of a fuel problem so blowing smoke and rough running do a compression test and look for a weak cylinder
Jul 09, 2012 | Cars & Trucks
Mower smoking and running rough
Check the gas you put in, it sounds like it had water in it.
Apr 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Lawn mower running rough
adjust the carby. also u might want to replace the diaphragm in the carby. might work wonders
Mar 31, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Sep 06, 2009 | Garden
Mower idles rough and stalls at times. Also blows
look by the carboreter and there is a little screw with a spring. turn the screw a half turn and try to start it, then try another half turn, and keep expirementing.
Jun 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
218 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
