Question about Lexmark X6570 InkJet Printer
My lexmark x6575 reads paper jam, and wont let any button be pushed, though there is no paperjam, ive done all but taken the entire thing apart, there is NO paper jam
I have had the same problem today and spoken to Jude at Lexmark Helpline. Nothing can be done apparently ! As it is just 2 years old and only guaranteed for 1 year.... This printer is probably used once or twice a week I am disgusted. Needless to say I won't be buying another one. (The cartridges are a fortune anyway)
Posted on Oct 05, 2010
Lexmark 5660 paperjam
printer says paper jam no paper in printer i have on pluged it to clear it and its continueing to say paper jam what should i do?
Oct 20, 2012 | Lexmark X5650 All-in-One InkJet Printer
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
Lexmark x6575 printer error message clear paper jam
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his Lexmark X6575 printer (a similar printer). The resolution of the problem once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam' message, even tho' there was no paper jam in my lexmark x6575, but the message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well just underneath this there is 8 little roller feet that sit on top of another silver/cream roller. Well in between these, in the very centre, you will see a little black plastic nib like thingy...While the machine is turned on, press this little black thingy (best to use a pen or something like, as it's small) and what should happen is the silver/cream roller will make a quick rolling motion....Hey! presto the 'jam message' disappears and the lcdmag-glass_10x10.gif screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
Sep 14, 2009 | Lexmark X6575 All-In-One InkJet Printer
Paper Jam
Usually with lexmarks its the sensor in there, it either has something going across it
Ths other thing it can be is the pinch roller that is in there if you can clean it with a qtip and achohol
Aug 13, 2009 | Lexmark X5150 All-In-One InkJet Printer
Dispalays Reads paper jam and wont disappear
Unplug the power cord then put it back up. This restarts the printer again in case the on/off button does not work to turn the printer off. Then check if there's a paper jam. To do this open the scanner lid and also the glass lid, just the way you access the inks when replacing them. Check to see if there's any paper stuck underneath the inks by the printer rollers along the paper path.
Apr 06, 2009 | Lexmark X4650 InkJet Printer
Error message on Lexmark x5470
hi there: we have the same printer and we had the same paper jam problem to correct: this we opened it up as normal and than got a flashlight and looked real closley at it and there was a verry small piece of paper in the side of it folded and caught in it we took a pair of tweezers and removed it and the paperjam was cleared try that ok the smallest piece will give you this error and wont continue untill it is cleared
best of luck mike
Feb 09, 2009 | Lexmark X2500 All-In-One Printer
PAPERJAM
hey gramma try to do one thing before even going for test page , open the panel and cover where u will be able to see the catridge ccarriers, try to blow air, or after opening the cover titlt the print and shake it gently sometimes due to some dust particle the paper jam happens
Feb 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X6570 InkJet Printer Logo
134 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
