Question about Kenmore 45799 Kitchen Range
THE RIGHT FRONT BURNER ON MY KEMORE SMMOTH TOP ELECTRIC MODEL 45799 STOPPED WORKING. IT SEEMS TO BE THE SWITCH TO TURN IT ON.
  • Kenmore Master
  • 12,061 Answers
This is a common problem and can be fixed by simply replacing the switch controller itself.
Because it's dealing with main voltages, and the catastrophic results of any errors,one should get this attended to by a professional. It will not cost too much, and then one can be sure that the unit is safe, just in case this failure is the sign of a more pernicious underlying problem.
Posted on Aug 08, 2010
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
The electronic ignitor on front right burner no longer works.
All ignitors should fire regardless of which burner is turned on. See if the right front will light up if you turn on another burner or look for a spark. If not, the ignitor is probably fouled and needs a good cleaning. If the right front burner will spark or ignite when a different burner is turned on, it is the right front control switch - not an easy fix. When cleaning the cook top, if you remove the knobs, any liquid that gets into the switches will short them out. Found that out the hard way.
Dec 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
My right front burner will not turn off on my electric stove top?
Hello, the switch controls the element ,if the element is staying on replace the switch.Please note any electrical repairs should be performed by an authorized service technician. good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Burner switches got wet, sparked, daughter put baking soda on them, and two front burners won't light.
I also got too much liquid into control switch area & had sparks. Mine needed a new electronic ignition system. I purchased my range in Jan 06 and they are covering it under warranty now, Nov 08. To open the top, unscrew 2 small screws inside the front top oven. Then unscrew all 5 burners (10 screws). Then you should be able to open the lid about 12". Repairman propped mine open with a screwdriver while he worked under there.
Oct 18, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Stove top ignition
I have a Kitchenaid Model KGCT365x and need to replace the igniter switch on the front right burner. Can this be done through the knock hole or does the whol glass top have to be removed? If it has to be removed, what is the best procedure to do this?
Jan 01, 2008 | Bosch HES 252/ HES 256 Electric Kitchen...
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Kitchen Ranges Logo
44 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
