Question about Casio G-Shock GW300CA-1V Wrist Watch
Cannot adjust time on watch hands manually digital ok it is an illuminator watch approx 9yrs old
  • cellarbarser Aug 08, 2010
    cannot adjust the time hands on the watch
  • Casio Master
  • 12,061 Answers
What has happened is the winder has detached from the winding mechanism inside the watch, You will need to take this to a watchmaker to effect a repair. It is NOT a costly job,and is quite common. It's just an effect of age in this case, and as related is quite common with this type and age of watch.
Posted on Aug 08, 2010
    thankyou for your comment we will try this as the other solution was to change digital time which we have no problem with very much appreciated margaret
  • 857 Answers
Step 1
Press the "Adjust" button. It's usually the top-left button, slightly smaller than the rest. When you have successfully pressed the button, one of the numbers on the screen (generally the seconds) should begin to flash.
Step 2
Choose which number you would like to change (hours, minutes, day, etc.) by using the "Mode" button (bottom-right) to cycle through each option on the main screen. You'll know when you have reached your target position because that number will flash.
Step 3
Use the top-right button (usually labeled "Start/Stop," or sometimes "Light on/off") to change the number once you have highlighted the position you wish to change. When you have finished making the desired adjustments, press the "Adjust" button again to complete the process.
Step 4
Use "Adjust" on any screen of your Casio G-Shock watch. To reach the watch's other screen, press "Mode" (bottom-right button). Most G-Shock watches have four screens total, including the main screen. On each screen, use the same process described above to make adjustments to the time (with the exception of the stopwatch screen, which does not keep time.)
Step 5
Note that on some adjustable screens, tools can be activated to change the function of your watch. To activate these tools, enter "Adjust" on any screen, then press the bottom-right button (usually labeled "Light"). Press "Adjust" again to return to the watch's display with the tool in place.
  • Jayant Jha Aug 08, 2010
    If you cannot adjust the time hand in that case it seems to be a mechanical problem and i will suggest you to counsult a technician because in order to fix it you will have to open it.
Need to set time on casio illuminator AW-81
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jun 29, 2011 | Casio Illuminator watch #AW82D7AV Watch...
I can set the digital readings but not the common watch hands, how do i set the hour hands?
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Oct 31, 2010 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
How to adjust the time for casio illuminator watch instructions s-1045DV
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Jan 27, 2010 | Casio Illuminator AQ150W1EV Wrist Watch
How do you move the hands of a casio 2747 watch [illuminator]
Below is the link for the manual with procedures to change both analog and digital time.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Oct 30, 2009 | Watches
I havE set digital time and how do i set the hands
Follow this link:
Rate, please.
Apr 01, 2009 | Casio Illuminator AQ150W1EV Wrist Watch
I cant adjust the minite hand backwards if the watch is gaining
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again.
One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait.
By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely.
Do not forget to rate, please.
Jan 14, 2009 | Bulova Watch
Setting time on casio illuminator watch
Dec 03, 2007 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
