Question about Craftsman 22" Gas Hedge Trimmer
My hedge trimmer stopped working - Craftsman 22" Gas Hedge Trimmer
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
boscia
  • 163 Answers
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
  • 398 Answers
SOURCE: Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Posted on Feb 26, 2009
rogrrabbit
  • 986 Answers
SOURCE: Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Posted on Jun 17, 2009
lemmingleejn
  • 173 Answers
SOURCE: Echo SHC-212 hedge trimmer starts and runs briefly
If it has not had a service recently, it's probably due by now.
Just take out the spark plug, and if it's black, or 'coked' up, just show it a wire brush.
Also, remove the air filter, and if you have one, show that, a compressor. (or alternatively, just bang it about a bit, till all the loose debris, and collective build-up, are removed.
Afterwards, (if that doesn't solve the problem),
you can adjust the timing, quite simply, by closing, or opening, the gap on the plug.
Or you can open or close the space between the contact, and the magneto.
Both can be very 'effective' means of adjusting the timing.
If problems still persist,
you know who to ask.
P.s. and don't forget to give the thumbs up ;)
Posted on Jul 31, 2009
Electric hedge trimmer want run why?
electric hedge trimmers have 2 switches to press before it runs
one is the trigger that you pull and the other is in the handle that you hold in your left hand
both have to be on before it starts
it is a safety feature to stop operators cutting off their fingers
Jun 09, 2016 | Little Wonder 2230S 30 Single Side Hedge...
Gas hedge trimmer blade locked up motor runs find
look for a bad nick in the teeth and file or grind it off smooth
Sep 16, 2014 | Poulan Pro PP2822 22-Inch 28cc 2 Cycle Gas...
Hedge trimmer clippers, elctric
Can't be too much to these things,so best bet is just take it apart.(My philosyphy is"It aint workin anyway,so just take a shot!"
May 11, 2012 | Garden
My Black&Deck 24" Hedge trimmer simply stop working. There is no action what so ever when I turn it on. Any suggestion? Do I need to locate and change the fuse? Thank you!
Check the black and white power wires to the motor. You will have to open the trimmer casing. I have 2, 18 inch B&D hedge trimmers and both of them stopped working due to wires coming loose at the motor. I re-soldered the wires to the motor and both trimmers work fine.
Jun 26, 2010 | Tanaka 30" Double Sided 24cc Hedge Trimmer
Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Gas won't pump through the hedge trimmer
carb may need to be rebult. sounds like a bad diafram hope this helps
Jul 11, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Craftsman 22" Gas Hedge Trimmer Logo
129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
