Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Have a Whirlpool side by side with a Matsushita compressor. Heard "pop" sound and terrible smell from fridge. Compressor (DS110Q22-R) runs, but moke comes from small black cylinder on left side of compresor. Is this the overload relay? Can it be replaced? Secured in three places by what looks like pop-rivets (not screws).
fridgetech
  • 473 Answers
SOURCE: fridge not cooling
Most of the time on a whirlpool the problem is the relay on the compressor sometimes called the start device. I would replace that first. If you need help finding the part let me know. I will need the complete model # from the sticker inside the fridge section. You can look it up with diagrams at http://www3.sears.com/.
Posted on Nov 09, 2007
  • 54 Answers
SOURCE: Whirlpool side by side compressor replacement?
uk price is about £250 fitted i done one about 2 months ago. or thats what my company charge
Posted on Feb 14, 2008
  • 1314 Answers
SOURCE: Whirlpool side-by-side melted relay.
did it burn through the compressor or is any of the pin sticking out
peyton32034
  • 410 Answers
SOURCE: fridge cooling shut down after noticing heavy dust on bottom coil
hey Bob I'm gonna steer you in a differnet direction. does you refrig have electronic controls or just plain ol adjustment knobs? If just plain ol adj knobs try turning the both knobs all the way off then all the way back on to the coldest setting. then firmly tap the knobs with the handle of a screwdriver or butter knife especially the one that actually has the off postiton. this is the thermostat and i'm thinkng it has gone bad on you. you mentioned that nothing was running so if the compressor relay was bad you would still hear fans running.
if this doesnt work I would need you to give me a model number off of the unit so I could point you in the right direction and help you do some continuity tests. thanks peyton
Posted on Mar 05, 2009
SOURCE: small refrigerator compressor overload relay cuts out
I am told if you measure two terminals and note the two with the highest resistance. Then measure each of the two terminals with the highest resistance to the common terminal they the two additional readings should read the same as the two terminals with the highest resistance when adding them together. If after adding the two there is more than 1/2 ohm difference one of the windings is shorted.
Posted on May 06, 2009
U-Line 75FF Bar refrigerator stopped cooling
it could be a problem start/run capacitor for the compressor or compressor failure
get a fridge technician in to test and get a quote
Most small fridges are cheaper to replace than repair
Jan 09, 2016 | U-Line Refrigerators
I have a Whirlpool mod. ED5LHEXD00 refrig. I left home for 3 weeks in Dec. with the house temp. set to 50 deg. F. I got home and discovered that the refrig./freezer was at room temp and all the food had...
If Fridge working fine now, the problem may be is Hydro Grid.
When the fridge just start, the compressor is running with high pressure of Freon. If Hydro power has voltage surge or power Off/On ( suddenly ), the compressor should be stuck, the overheat protection switch will actived, than fridge will stop working.
The noice of "click" - properly is overheat switch auto-reset.
May 28, 2017 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Hot compressor
We cut compressor open to see what happened to it. Grounded and found couple more issues.
May 12, 2012 | Matsushita DD73C14GAU6 1/4 HP R134...
Whirlpool fridge compressor will not kick in
call your parts store,give them the model number,open the fridge door on the right hand wall up near the ceiling you'll see a tag with the model number,tell them you need a start device and they will sell you one.do you hear a clicking sound or smell anything,when my device went i could smell it.unplug the fridge,remove the bottom panel in the rear and on the compressor you'll see a clip,pop it off,slide the start device off,shake it,if you hear pieces rattling around inside it,it's bad,leave the wires on until you get the new part.next time send the model number,a bad timer,board or cold control could also cause this.if the machine gets stuck in defrost the compressor won't run.if you open the freezer door and the fan is blowing,it's not in defrost and most likely it will be the start device.hope this helps.
May 07, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirpool GS6SHAXLB03 Refrigerator or freezer do not cool.
This sounds like it's out of freon. Not just low but out. That clicking noise is a thermal overload shutting down the compressor. If you continue let it just click away it will burn this overload out and the compressor will have to be replaced. If the refrigerator just started doing this suddenly it could be that the compressor is locked up. If it has external capacitors either the start or run capacitor could be bad. If the capacitors are good then you could try a hard start kit to try to unlock the compressor.
Jun 30, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Whirlpool fridge and freezer will not cool
Replace the start relay on the compressor.
Jun 08, 2009 | Whirlpool Freezers
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
BAD SMELL COMING FROM UNDER MY WHIRLPOOL SIDE BY SIDE FRIDGE. I SMELL IT WHEN THE FAN BLOWS. IT SMELLS LIKE URINE.
check its not the drained ice water which collects on a pan over the compressor. the compressor heat is supposed to evaporate it .that foul smell might be due to that.
if that is the case ,switch off fridge , clean , dry , the pan & see .
May 31, 2008 | Whirlpool Refrigerators
Fridge not cooling
Nov 09, 2007 | Whirlpool ED5FTGX Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
130 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
