Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
I bought my Kenmore Oasis HE 27082 in March of 2007. Approximately 4 months after I got the washer I started having an error on the washer that said "LD". The manual and repairman said that "LD" means Long Drain, and that it probably means my drain pipe is clogged or not working. Two different Sears repairmen have come to try and fix my washer, one replaced the control board, and the other replaced the motor. Both times it didn't fix the problem, and both times they couldn't really seem to diagnose the problem correctly at all.
I've diagnosed this problem pretty specifically and know exactly when it will malfunciton. Right before the washer should Start Spinning the clothes, it will just sit there with the motor running for a few minutes. Then the "LD" error will come up. Recently after this "LD" error comes up even when I push stop twice and restart a new cycle, it will not start a cycle at all. No water will come out and the motor is just running for a few minutes and then the "LD" error will come upo again. I've also tried unplugging the washer for a minute and sometimes the washer is able to start a cycle again. However, even though the the washer seems to work again, it will eventually stop in the exact same place with the "LD" error.
I've checked the drain pipe thoroughly and have concluded that it is working perfectly. The 2nd repairman though my washer was "oversudzing" but I have cut down and use extremely small amounts of HE detergent. I've seen in some of these posts that sometimes the washer sends a false signal to the to the control board and will not initiate the spin cycle. Is there a way I can manually get the washer to just do the spin cycle? Is there anyway I can fix this problem myself? Your help would be greatly appreciated, thank you in advance for your time.
  • 2 more comments
  • Anonymous May 06, 2008
    Same problem, same machine and model number. I wish some had an idea of what it is.
  • whit1974 Jul 02, 2008
    Same problem- different model Oasis 2703.  Three repair men out this week...they think I'm nuts!
  • mcellligott Sep 24, 2008
    I also get the "LD" error. I ran current to each pump directly with a cheater cord and they run fine. I can also drain it this way. The washer never fills with water. I start the cycle, I hear what I believe is the recirculating pump for about 20 min. and then the LD error.
  • cvanzip Oct 20, 2008
    I am having the same problem. The washer is 11/2 years old! This should not be happening. Is there a recall?
  • 868 Answers
Remove the harness and replace it is what this will lead to,just watch and you'll see
Posted on May 26, 2008
Your pressure switch is bad. Try leaning the machine forward. The water in the bottom runs to the front and fools the machine into the spin cycle. If this works for you, it is the pressure switch. Now the real kicker, to replace the switch you need a new computer. About $150 fix.
Posted on Jun 19, 2008
  • 117 Answers
LD means LONG DRAIN
Did him look at the pump or replace that??
they should.
Posted on May 09, 2008
4 Suggested Answers
SOURCE: LD error on Kenmore Oasis HE 27082
I had the same problem with F1 and F68. I just bought a $345 new computer for my washer. These machines are defective. Mine was purchased in Nov. of 2006 but not even out of the box until Jan. 2007!!!
Posted on Apr 29, 2008
melnavz
  • 1226 Answers
SOURCE: Kenmore Oasis HE 27082 Displays "LD" error falsely
Since that you let repairman do twice and didn't fixed the problem, I think your washer have still warranty from the vendor. and they repair it free.
Please verify the panel board of the machine maybe got grounded in the wiring or got wet. How ever you can do that in your own you should consult the repairman on that matter. however the two repairman did not resolve, so its better to bring the washer's to the vendor. im sure they can fix the issue or you will be enlightened by their valuable suggestion and solution.
may this help
melnavz
Posted on Oct 18, 2008
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite oasis 27082 - lid won't lock
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
KENMORE OASIS WASHER DISPLAYS Ld CODE AND WILL NOT DRAIN WARER FROM TUB
I have the kenmoe Oasis he and out of no where this machine wont work. You push the start button and select and that is it 'Nothing" you have to unplug it and start over again but the same thing will happen "nothing" and plus the water wont drain! I feel this is a rip off machine. house wife
Dec 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
may this help
melnavz
Oct 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
What is the mean of LD code for kenmore oasis he?
See the following Whirlpool Service manual for the Oasis / Cabrio washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Jan 22, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis code ld can you help
HI There
I want to say is Merry X-Mas and a Happy New Year. I have found what you need and hope this get's you in the right direction. Let me know how it went.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best Regards Richard
Dec 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer displaying "LD" and constantly beeps
Sometimes the LD on certain machines can be decieving, It's possible that the error is pointing to a lid lock issue. I'm a sears tech but have logged of my work computer for the night so I can't look it up right now. I just happened to stumble on this forum. In all appliances there is a tech sheet hid somewhere. This will give you more information. On this model, if you press and hold anykey for 3-4 seconds, let it up for 3-4 second and do that 3 times it will show more codes and go into a test cycle. Don't worry you cant screw anything up in the controller. If you or anybody needs help on appliances you can drop me a line. I have been a Sears tech for 15 years and have seen a lot of stuff and learning more all the time. scottowa at hot mail
Dec 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Oasis washer displays code Ld and wont fully drain
LD means long drain. Check to see if there is something clogging your drain hose. If not remove the drain pump from the bottom of the washer tub and clean it out. Also clean the recirculating pump. That should fix it. if not replace the drain pump.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
385 people viewed this question
Sal De
fordexpert
Robert Rankin
