Question about Toshiba 53H71 53 in. Rear Projection Television
No video, black screen. audio is working. tv shut off autmatically
    Sergeant:
  • 252 Answers
You have a problem in the high voltage section of you television most likely one of the driver out put chip on the CRT board plugged directly into the back of your Cathode Ray Tubes if not check the the horizontal and vertical driver chips if they are getting extremly hot this could be your problem
Posted on Aug 08, 2010
  • peavey123 Jun 24, 2011
    On Toshiba 53H71, I replaced both STK chips, replaced fuses (2 amp, 1.25 amp, and 5 amp) and had proper soldering done. When I plugged it back in got a bad horizontal, vertical and convergence was off so tried to use remote to adjust all, but could not fix the hor/vert so the convergence did not work either. Now I just get a black screen, no audio, no menu. Any thoughts?
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
Samsung lcd Backlight Failure
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 26, 2014 | Samsung LN40B630 40 in. LCD TV
Screens nturns black but have audio
Ur video board is dead.Or the video socket connect to the CRT(tv tube) is cold solder.
Sep 06, 2009 | Sony KV-27V40 27" TV
No Video but have Audio
I found my product manual and called the Tech Support line. They said it was a problem with the display and would have to schedule and appointment to fix it.
Jun 19, 2009 | Dynex DX-LCD32-09 LCD TV
Black screen on ps3
try to unplug the system and turn it back on, some times you can get it to work that way, or it could be the audio video cable connected to your tv
May 12, 2009 | Sony Playstation 3 (PS3) Console
46 inch Sony flat panel lcd has vertical red and green lines down right side of screen and you can be watching tv and picture will go right out and leave grayish blank screen until restart. Black...
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Apr 28, 2009 | Sony Televison & Video
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Element hdtv flx3210 shuts video off after a few seconds.
Send the set back for service.
The power supply most likely failed, or another circuit board has failed and the set is in the protect mode.
I would consider to see if the dealer would exchange the set for a well known quality brand name set and pay the difference.
Jerry G.
Jul 11, 2008 | Televison & Video
Video and Audio Inputs will not work
I think you need to replace your video drum. You can get replacements for your brand of Combo on the internet.
Mar 30, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Toshiba 53H71 53 in. Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
