Question about Refrigerators
Does not seem to cool anymore and freezer section is only around 0 degrees max
Montgomery Ward Refrigerator model #58B33739106, does not cool, now the freezer isn't cooling.
Posted on Apr 27, 2008
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Why is the refrigerator section not cooling?
Sounds like a defrost problem,either bad defrost heater or bad defrost thermostat
Jul 07, 2015 | Electrolux EI28BS56IS (278 cu ft) Bottom...
How to lower freezer temperature
Not sure what you mean by the freezer too cold? The freezer section should be at or below 0 degrees C or 32 degree F. if its working properly. If the FF section is too warm and your temp control door or vent is at max cold either the vent is not moving (stuck in the closed position) or the fan in the freezer is not working.
Nov 10, 2014 | Frigidaire Refrigerators
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Jun 24, 2009 | LG LRTP1231W Top Freezer Refrigerator
Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Oct 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator cooling to 59 degrees in non freezer compartment
If the fan is running you more than likely have a defrost problem.
Look at the back wall of the freezer section if it is frosted up. it's not defrosting. This keeps the air from circulating through the refrigerator section.
May 21, 2008 | Estate Refrigerators
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
