Question about JVC HD61G887 HDTV
How can i get a face screen for my hd61g887 the screen is broke the lamps are good you can watch tv but theres a crack on the screen
    Sergeant:
  • 252 Answers
Just go online and order it directly from JVC
Posted on Aug 08, 2010
REPLACED BAULB AND RED LIGHT BLINKING AND WILL NOT COME ON
Look first to see if lamp went in correctly, on most sets if look carefully you will be able to see if lamp fires up for even a few moments or not.
The lamp is powered by a ballast and that could also be bad, the place where it connects (usually two pins) goes directly to the ballast.
If issue is different from before the lamp was replaced you may have a new lamp that is bad, its rare but can happen.
Dec 23, 2012 | JVC Tv Lamp Ts-cl110uaa Hd-61g887 Hd61g887...
Akai rear projection tv suddenly stopped working.
This set with Akai is actually made by Samsung (they own and use the Akai name).
If lamp light etc and you have heard a cracking sound it may be the color wheel.
You can remove the lamp and look where it faces--look and the wheel can be seen----is it shattered or missing plastic pieces?
The wheel commonly fails in this fashion and is turning at over 12,000 rpm. The set will detect if the wheel is stopped or moving too slow and just what you describe will happen.
Wheel is widely available and You Tube has video instructions for replacing them by model number.
Questions?
Mar 28, 2012 | Akai PT5492S 54" Rear Projection...
Our cat knocked over our flat screen LCD tv The sound still works perfectly however we have no image Can anyone suggest what may be wrong and how much it would cost to repair?
The good news is that the TV is not broke and can be fixed. You will first need to check for any cracks on the front screen of the TV. If there are any cracks then you will need to replace the screen itself, which ranges from $100 for smaller sized TV's to $500 for larger sizes. You should probably call a local repair shop and ask them for a quote. If there are no cracks then the problem may be from within the TV. If this is the case, then you will need to figure out what part of the LCD is broken. It may be either the LED lights or CCDL's (cold cathode fluorescent lamps) that are broken. You should take it into a repair shop and let them fix it, because messing with the LED's or CCDL's is very dangerous and should only be done by a professional. The LED's should cost $100 tops to replace and the CCDL's should cost about the same. Hope this helps!
Jul 01, 2011 | Sanyo Televison & Video
The glass face has cracked diametrically from side to side
mcdevito75 here, If it is a crack and not just a scratch almost ant watch repair shop could replace the crystal (glass) a crack means replacement and a scratch might be able to be buffed out, Expect to spend $30.00----$60.00 either way.
Jun 22, 2010 | Skagen 355LGSC Wrist Watch
I replaced the lamp and the screen still say replace lamp and reset timer
Go into menu and keep scrolling down unitil you get to reset lamp timer. Press right arrow press ok.
Nov 21, 2009 | JVC HD61G887 HDTV
Broke screen
The mirrors are just mirrors, any paint/glass store can get new ones cut for you if you take the pieces of the old one in. The screen is going to be a hard one though. Actually if you can find (which I am sure you will be able to) another broken tv, very seldom is there any damage to the screen itself. There are two parts to the actual screen though, a tinted piece that dims the picture and a frosted piece that catches the image. Good luck!
Jun 12, 2009 | Sony KDF-E42A10 42 in. LCD Television
Replaced parts--here's where we/re at
Check all tubes Red ,Green look for crack or broke some even leak fluid out on board.
Aug 29, 2008 | RCA D52W19 52" Rear Projection Television
JVC HD61G887 HDTV Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
