Question about Grilling
My knob was on fire today and fire beneath it melted knob sticking out
    Problem Solver:
  • 16 Answers
Burner is clogged or faulty and allowing flame to "back up." If it is a Jenn-Air, call them to replace all burners. You may have a damaged valve(s) now due to the excessive flame being where it should have not been. I would not use grill until further inspection.
Posted on Aug 25, 2010
Why can't I register it?
Fire tv stick can't register - Amazon.com
https://www.amazon.com/gp/.../ref=cs_hc_g_tv?...
Amazon.com, Inc.Received my new fire tv stick today. I'm able to get past the wifi connection screen. But registering it with my Amazon account is I'm possible. Tried over 50 times ...
Amazon.com Help: Basic Troubleshooting for Amazon Fire TV
https://www.amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.Make sure your Amazon Fire TV device is registered to your preferred Amazonaccount. To verify your registration ... Can't Access External Storage. Note: External storage options are not available for Fire TV Stick. First, make sure you're using ...
Amazon.com Help: Can't Connect to Wi-Fi
Dec 26, 2015 | Amazon Fire TV Stick
How do I register?
If you are getting trouble regarding amazon fire tv stick device then fix problem to read guide at
https://echoalexasupport.com/fire-tv-stick-support/
Dec 25, 2015 | Amazon Fire TV Stick
How do i assemble a stanley block plainer
1, Lay pencil on the table top, place body of plane with the front (toe) resting on the pencil, so the light passes beneath the front and middle of the plnes body.
2, lay blade, bevel side up, in to body of plane, ideally sharp end is sticking out of the mouth ever so slightly., 1/2-1mm.
3, Release the knob or lever cam on the lever cap and place on top of blade.
4, tighten knob/turn leaver till it tightens on the blade. and your ready.
5, If the blade isn't protruding the mouth correctly then:
6, Loosen a knob/lever a little to allow the blade to just move, adjust the blade forwards/sidways, lock it in place by re tighten the knob/lever.
Plane a thin piece of wood, re adjust as necessary till wafer thin shavings collect in the mouth ontop of the bevel.
Aug 29, 2014 | Bailey Stanley 12-920 - Block Plane
Your Question Preview Fire Magic A790i Logo Problem with A790i Firemagic a790i flames pop and knobs get hot Posted by Author imageGuest on 3/24/2013 Details not getting good pressure to all 3 b
It sounds as if the burners may not be properly seated on the valves. Instead of all of the gas flowing into the burners, some of the gas is escaping behind the front panel and creating a fire behind the front panel which would heat the valve shafts and melt the knob inserts. This call also be caused by partially blocked burner venturi and valve orifices.
Check to make sure the end of each valve is completely inside of each burner.
Mar 24, 2013 | Fire Magic A790i
Kitchenaid gas cooktop fire
First You should have a technician to come and check it out. But my first thought you have a obstruction in the tube going to the burner, Might be a piece of food that has fallen into the Ventura,.
Dec 18, 2017 | Cooktops
We have the Craft Couture bead kit but we are missing the directions. You are supposed to place the small plastic beads in a holder to make a pattern and then iron over it to make it all fuse together....
You should be using Parchment Paper. We used Wax paper too, but it doesn't work as well. Ironing times vary depending on how much you want them to melt. We have melted some to the point they no longer have the holes in the middle of the beads and others just enough to stick the beads together. The barely ironed ones tend to fall apart eventually. The fully fused and melted ones are permanent.
Sep 14, 2017 | Toys
Dishwasher won't start - green light flashing
Probably the machine is not getting any water. Just had this problem today, after a plumber had been here to fix the sink, he had turned of the water supply to the dishwasher, and forgot to turn it on again.
The mechanism for turning on and off the water supply is simply a "stick" that you can turn around. Mostly, the water is getting inside the tubes when the stick is parrallel to the tubes, and the water is stopped when the stick is not. To us, it is a red handle, just beneath the sink.
Sep 05, 2009 | Whirlpool Dishwashers
Grilling Logo
188 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
