Question about Valor IDA-700W Car DVD Player
I have a valor ida700w dvd cd car stereo in my truck and the radio works but the dvd cd player will not play. can you troubleshoot my problem please
    New Friend:
FYI..... for any one with a Valor IDA-700w.
The dvd/cd drive assembly was poorly designed.
the clamp that secures disc as it rotates mounts
on one side with a plastic pivot,fine,but the other side
uses a longer metal arm that also has the clamp spring.
The spring exerts too much pressure on the arm and cracks
its plastic anchor.
I repaired mine with JB weld and it plays cds but will not
play dvds,just hunts and hunts or skips.
Oh well,radio plays great-by the way, an undocumented feature
of the unit is that it has a Zoran decoder chip for Dolby Digital
and DTS-too bad drive is inferior.
DTS cd discs play great when it works!
Posted on Nov 11, 2012
  • Kahn Singh Nov 11, 2012
    its plastic anchor.
2 Suggested Answers
alpug
  • 1961 Answers
SOURCE: where is the fuse in a valor its-702w car dvd
you need to open the cover of your dvd player.the fuse is installed conected to the positive supply of you player.
Posted on Jun 04, 2010
When loading cd, it says bad
It's likely there is dust on the CD player lens. Many DVD units have two lens units, one for DVD's and the other for CD. You will to clean the CD one.
Mar 26, 2017 | Toshiba Televison & Video
Can't hear right speakers
ok...got it..so..is your player have a stereo option for the DVD..can you make sure that's selected?
Mar 17, 2008 | Jensen VM9020TS Car DVD Player
Do you know were I can get a wiring harness for DDA 650W VALOR car stereo
no wiring diagrams found
only this
Features:
6.5" Double Din Size Fully Motorized IN-Dash Monitor w/DVD;
2 DIN;
16:9 Wide Screen;
Compatible with DVD/VCD/CD/MP-3/CD-R/CD-RW;
"True All-In-One" (no separate brain);
Built-in DVD;
AM/FM radio tuner;
Wireless remote;
3 video inputs;
1 aux input;
2 video outputs;
Front and rear audio outputs;
Subwoofer output with adjustable crossover;
Center channel output;
Reverse signal input for camera;
Dual zone playback function;
AC-3, Dolby Prologic II;
Dolby digital surround (5.1CH) audio output;
PAL/NTSC compatible;
DVD/CD changer interface;
5 x 45 watts;
Oct 23, 2016 | Cars & Trucks
No sound while playing a dvd or cd in my valor dvd headunit radio has sound just not when i play a dvd or cd
Make sure your cables are in right spot on both..
DVD player (if using the composite cables yellow white red)
on DVD makes sure it says Video OUT and color match
TV look at the back and dont just plug in cuz you see colors. look at rear.
On Back where they are at should say Video 1 2 3 whichever one has the red yellow white cables and say Video IN. match colors then try. should work.
Mar 02, 2014 | Car Audio & Video
Valor DDA-650W in car av system Just bought the car it was already hooked up It says Bad disk with DVD's and no disc for Cd's. I'm guessing I should just buy another but I wanted to make sure there was...
You can always try the last resort of a cleaning disk (EX: DvdDr)
That would be your last option as far if it will work again.
Please rate if this helped :)
Mar 09, 2011 | Valor DDA650WT Car DVD Player
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Valor IDA 700w won't play movies
TRY CONECCTING THE BLACK/GREEN CABLE TO GROUND
Nov 21, 2008 | Panasonic DV-169 Valor DVD/VCD/CD/MP3...
Valor IDA-700W Car DVD Player Logo
255 people viewed this question
Top Valor Car Audio & Video Experts
David Payne
David Payne
hoyzee1
Tom Chichester
Are you a Valor Car Audio and Video Expert? Answer questions, earn points and help others
