Question about Fisher and Paykel GWL11 Top Load Washer
Have a burning smell ,coming from the machine ,also the machine trips out ,won't drain either unless I spin the little motor by hand under the wash bowl,thanks
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now did you notice any corrosion on the pump?Was the burning smell coming from the pump?Could you please confirm the model number of your machine for me.Try not to use the machine until this fault is rectified as the control module might become faulty and then the repair will be expensive.Please reply with additional information on the questions and I am sure I can help you repair this fault.
Posted on Aug 08, 2010
My machine fills with water and before the drum starts to rotate, it blows the fuse.
If your talking about tripping the breaker its designed to trip under load. Yes if something is keeping the drum from turning that put a load on the breaker and trips it..It will keep tripping until there's no over load on the drum...I'm guessing your talking about a washing machine... You can take the belt off the motor and if the motor is good it will turn on but not spin the drum...Then you know the motor is good and something is preventing the drum from turning. And if the motor is bad you can smell a burnt smell if you get close enough to the motor..Hope this helps
Jul 01, 2017 | Washing Machines
Ken more stackable washer has a new belt but won't
I'm assuming the motor pulley is spinning?? Unplug the machine and Take the belt back off and see if you can turn the tub by hand and then each of the pulleys by hand. If the tub turns easily by hand ( maybe in only one direction) the transmission should be ok. If you can't easily turn it in at least one direction the transmission has the problem. The problem may something stuck in the drain pump like that missing sock you've been looking for, Unless yours has the small electric drain pump. Not sure which you have since you didn't provide a model number.
Best of luck, John
Sep 20, 2014 | Washing Machines
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
I have a maytag washing machine model A712, during the spin cycle there was loud screeching noises and burning smell. What could be the problem.
problem could be the gearcase or the motor, to find out remove the motor and turn it with your hands to hear any abnormal sounds coming out, and also try to smell the motor see if it has a burning smell
Oct 16, 2011 | Washing Machines
ADMIRAL WASHER MODEL NUMBER LNC6753A71 HAS BURNING SMELL AND WON'T PUMP AGITATE OR SPIN BUT MOTOR IS RUNNING
its probably the drive belt that you smell burning under the basket,but there are numerous things that can cause it to burn,so you need to find where its froze up could be a clutch,the brake,the drain pump
Aug 02, 2011 | Whirlpool Washing Machines
Hi. my ge wjse3110a won.t spin unless is start spinning it first by hand
The motor is going bad...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2010 | GE WJSE3110A Top Load Washer
Will drain most of water but will not spin and smell something burning
The motor is probably stuck and burned. Open the door and turn the drum manually. You should be able to turn it easily by hand if the motor is not stuck.
Remove the back panel and use your sense of smell to verify where the burning smell is coming from. The possible source of the smell is the motor or the motor control board located on the left side of the machine viewed from the rear.
Let us know the source of the smell for the replacement guide and for further troubleshooting if necessary.
Feb 22, 2010 | Washing Machines
My beko washing machine smells of burning
i need a motor circuit to test the motor of a defy automaid it does not spin fast
Nov 24, 2009 | Washing Machines
Intermittent agitation and spin, mostly just hums, burning smell after replacing drive coupling
sound as if the motor or someting else is sticking release the belt on the motor. check belt for damage. check motor by turning it by hand to see if it is free.
May 12, 2009 | Washing Machines
NO Agitator, draining or spin
Since the breaker did not trip i am going to assume that the washer stopped because the motor overload switch tripped or contacts burnt. Was there any smell of any burning (electrical burning)?. It could have stopped because a contact on the timer got burnt too. Have a look also at the water level swirch
Regards
Oct 04, 2008 | Whirlpool LSB6200KQ Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
154 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
