Question about Whirlpool GEW9868K Electric Dryer
Whirlpool Clothes Washer GEW9868KT2 touch pad does not light up. Cleaned all electrical connections with contact cleaner and worked fine for a few days. Had the same problem with Dryer GVW9959KT1 touch pad and cleaning electrical connections worked!
5 Suggested Answers
SOURCE: whirlpool dryer
replace the thermostat
Posted on Apr 29, 2008
SOURCE: Whirlpool electric dryer. Clothes stay soaking wet
You were absolutely right about it being a venting issue. Although we thought we had it all cleaned out there was still a ball of lint blocking the air flow and causing the problem.
Thanks for your help.
Clint
Posted on Apr 15, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
SOURCE: My Whirlpool Dryer LER4634EQ2 Electric Dryer
I am having the exact same problem, did you ever get an answer to your question? Did you hire someone to look at your dryer?
Posted on Jan 11, 2011
Error code popped up. What does F2E1 mean?
Whirlpool: F2-E1 - Touch Pad (Keypad) Cable Unplugged - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Unplug unit for a few minutes to see if it will reset.
If that doesn't work
You can try opening it up and unplugging the ribbon wiring connection and cleaning the contacts with a pencil eraser.
Hope this helps.
Mar 15, 2016 | Kitchen Ranges
Dryer is smoking and clothes are too hot to touch
Tara, We are sorry to hear about your Dryer. We are happy to look into your concerns but we will need your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase emailed to Whirlpool_Digital@whirlpool.com.
Jun 07, 2017 | Whirlpool WED5300S Electric Dryer
Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
Looking at the manual of my Whirlpool front loader gives me the following advice...
CONTROL WON’T ACCEPT SELECTIONS
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the drain hose and drain
pump filter are clear of foreign objects.
3. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
4. Unplug washer or disconnect power.
5. Check harness connections.
6. Plug in washer or reconnect power.
7. Verify CCU operation by running a Diagnostic test or any
cycle
BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9400 PT4 on any of the cycles, runs 1/4 of the way through the was cycle and stops and starts flashing F 06, pushed cancel once then started the cycle again this worked for awhile. Then...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jun 16, 2009 | Whirlpool GHW9400 Duet Washer
E0 F2 Error on Whirlpool Golf Super Capacity 465 Oven
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Jun 02, 2009 | Whirlpool GSW9800PW Washer
Dryer starts to run on its own
Some dryers have a touch up cycle that runs automatically to keep clothes from wrinkling if they are left in the dryer.
Some touch up cycles are selectable. Some are automatic.
Mar 07, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool cabrio electric dryer heats and tumbles, but clothes don't get dry
remove your duct from the dryer. DRY a few loads,IF the unit works fine with the duct off, You will need to get the vent to the outside cleaned
Feb 23, 2009 | Dryers
Washer goes right to drain when started
This error occurs if the touch-pad/LED assembly is not
able to transmit/receive data to/from the central control
unit (CCU).
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting
different cycles and changing the modifiers and
options available to confirm the touch-pad/LED is
responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit
(CCU).
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F2.Q1
Not sure what you mean by "Q1 Touch FMEA" above, but F2 error code indicates a bad keypad or sometimes a bad sensor.
Since it's brand new I would first consult the manual. If you don't have it still, you can download it from the owner center here: http://whirlpool.com/custserv/index.jsp
If you still have trouble, since it's new, it should obviously be under warranty, so I'd contact them (same page as shown above) to get it repaired under warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 01, 2008 | Whirlpool GH7208XR Convection / Microwave...
Whirlpool GEW9868K Electric Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
