Question about Imperial IFS40 Deep Fryer
I purchased a 40 fryer for church....I needed a 240 single phase...I recieved a 240 3 phase. Is there a way to convert?
  • Imperial Master
  • 43,501 Answers
Yes but it would not be economical to do it...it would cost more then sending it back for the correct phasing...to many things to convert and change...they may however be able to send you the proper heating elements and safetys, so that you can convert it...would depend on if the proper elements still fit in the same spaces provided...I would call the company and see what they want to do...
heatman101
Posted on Aug 08, 2010
  • svenkama Oct 11, 2010
    Hi
    I am having the same problem i have bought 2 deep fat fryers which are 3 phase and i cannot return these items back to the seller as it was bought on ebay a long time ago.How can i operate the fryers on single phase power.
    It would be great if you could please advise
    Thanks
    Kovi
    svenkama@sky.com
Wells deep fryer 208 volt 3 element. 1 element works other two don't working left to right. Continuity good resistance good. Relay problem?
Sounds like this maybe a three phase unit and you are powering it off on single phase power. Most can be converted to single phase but will draw three times the current and requires some wiring changes. It needs to be on a three section breaker for 3 phase.
Jul 21, 2014 | Kitchen Appliances - Others
I need wiring diagram to broaster 1400E chenge a 220 voltios
GVE_10
That is a tough one, as 1400E has been out of production for 30 years. Parts have been discontinued for about 20 years. When you say you need to change voltage, that machine was made as 208 0r 240. 240 machine was always fine on 220 volts. 208 machine could burn out heating element over some time, but since you cannot buy other elements anyway, I would just go ahead and use the machine. If your real question is how to convert from 1-phase to 3-phase or vice versa, that is different story, and I can help you with that.
Jon
jondf1@gmail.com
Dec 07, 2012 | Broaster Pressure Fryer
I am trying to convert a wells f-67 to three phase and need a wiring diagram please help
Hi there.
You can download Wells F67 electric fryer at http://www.wells-bloomfield.com, it contains conversion of wiring from single phase to three phase, just click the owner's manual on Service and Support page.
Regards.
Oct 17, 2011 | Wells F-67 21167 Deep Fryer
I have an old GE deep fat fryer,m/n CK40B, which has no wiring diagram, I am trying to use it for my shop, but can't find any diagrams anywhere on this fryer. It was wired for 3 phase, I am trying to...
If you feed single phase into the line terminals, you will get only 1/3 the heat wattage. To get all heating elements working on single ph, you'll have to separate the common ends of the elements, then connect all 3 in parallel. Keep in mind, doing so will raise your line amperage x3 also. That may put you over the contactor's max rating. Another thing, the contactor will activate on only one sequence of single phase. You may need to move the line to another 2 of the 3 connections.
Feb 02, 2018 | GE Kitchen Appliances - Others
HELLO , i have a Powcon 300 SM i have understood how to change from 460 volt to 230 volt three phase but i can not figure out how to change the whole machine over to single phase 240 ...
Look for a "Phase Converter" at Harbor Freight or look in You Tube for info on building one. If you have a lot of welding to do, I would get a better quality converter than they have at HF.
Nov 29, 2017 | Computers & Internet
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Nov 03, 2009 | Kitchen Appliances - Others
Converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
May 07, 2009 | Kitchen Appliances - Others
Change 208v heating elements to 240v.
If your supplying 240 vac to a 208 vac element it will work but shorten the life of it.Goto 3wire.com and register,they should have a 208vac element.The wild leg could also be an issue but if you get a 208 vac element it shouldnt hurt it that much.Why you would be getting a reading of 240 vac on l1-l2-l1-l3-l2-l3 is strange.Let me know.
Mar 25, 2009 | Cecilware EFS-40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
206 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Joseph Hoffmann
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
