Question about Sanyo DP19648 19 in. LCD TV
Power light keeps blinking on my sanyo DP159647 but wont come on
What can I do to fix my Sanyo tv off and on issues? It keeps blinking or flicking off and on screen but it works good and stable when playing video games I would appreciate any tips or help thanks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 01, 2015 | Sanyo DP50749 50 in. Plasma TV
Sanyo projector i change the bulb but it wont start up the bulb how to reset?
http://www.google.com.et/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CBsQFjAA&url=http%3A%2F%2Fforums.cnet.com%2F7723-13973_102-398100%2Fdlp-twon-t-turn-on-blinking-green-lamp-light-then-shuts-dow%2F&ei=-VnbU_8Hg9XRBeWdgIgM&usg=AFQjCNGp5RYvSkK-2YKIqjHeH2oxVnzU-Q&bvm=bv.72197243,d.ZGU
Aug 01, 2014 | Sanyo Xga 4500 Ansi Projector
I have a sanyo 32inch tv an it wont tyrn on it has the blue light but when I turn it on it just keeps flashing but flashing like the light is loosing power?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Jul 31, 2014 | Televison & Video
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Wont go off of standby
Try unplugging the unit for a couple of minutes and see if that works.
Jul 24, 2009 | Sanyo DP19648 19 in. LCD TV
The power light on my computer keeps blinking and it wont turn back on
I think the problem with the RAM. please open your CPU cabinet and clean the RAM and fix it back. I think it will help you to overcome this problem.
Thanks.
Apr 30, 2009 | Computers & Internet
Sanyo DP19648 19 in. LCD TV Logo
294 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
