Question about Onkyo TX-SR501 Receiver
I just got this reciever it has been sitting for 5 years. Hardly ever used. I plug it up can't get power to it or the woofer.
  • 857 Answers
IT seems to have some disconnection on the mainboard thats the reasn for the problem.
In order to fix this you will have to open it and then check the fuse and the wiring on the borad then check and make the appropriate repair, if you are not an exert in this please counsult a repair guy.
Posted on Aug 08, 2010
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
I have a jvc seteup but reciever is broke.is there a way i can get a adapter to plug sub woofer with power amp into a a yamaha reciever?the plug that goes from sub woofer also powers other speakers, cable...
Here's a manual.
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
That cable not only carries audio but it also powers the sub and other channel amplifers. Even if we could supply the pin-outs for the channels I'm not sure what we could do to provide subwoofer power. We're talking about a major rework.
This is a highly proprietary design, meaning it's really not very adaptable to normal spec audio equipment.
There's a flat-fee repair service for the receiver ($99.95, free return shipping):
http://cgi.ebay.com/JVC-TH-C50-TH-C5-TH-M505-Repair-Service-/360178567658?pt=LH_DefaultDomain_0&hash=item53dc50c9ea
Maybe they could fix your receiver.
You COULD try to reach the manufacturer for other options.
http://www.jvc.com
800-252-5722
Jan 12, 2011 | JVC TH-M505 System
I was given a Sharp HT-DP3000 reciever and all the speakers that go with it.. but I don't know how plug in the speakers into the wire there is a box for the two surround and a separate box for the right...
Do you have speaker wire if not you will need some, the wire is cheap about $5 bucks a roll your local department store will have it. You see a red and black tabs on the back of the unit and on the back of each speakers you push down and stick one wire in the hole. red will be your + and black will be - The two surround go on the back wall behind your seat.The center will sit on top of TV and the sattalite speakes go beside the left and right side of TV. and the sub sits on the floor in hidding behind something or under a table. (P.S, Make sure the wire is shaved about 1/4 of inch before you stick in the wire DO NOT plug the power cord in, intill you hook up all the speakers this could damage the unit. You do not need a sub woofer, if you have one great If not don't worry that will not damage the unit it has a internal switch to turn on/off the sub woofer The sub woofer offers extra deep bass that you can't get from the sattalite speakers.)
Aug 31, 2009 | Sharp HT-DP3000 System
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
How to connect speakers to the sub-woofer and my iMac.
i believe that plug is special because it feeds not only audio signal but also voltage to power the speakers. so unless u know that the speakers will get power from the plug, it will probably not work
May 24, 2008 | Harman Kardon iSub Computer Speakers
Subwoofer preout and bass
did you tell the receiver that you have a subwoofer connected (thru the quick setup)?
Apr 02, 2007 | Pioneer VSX-D514 Receiver
Onkyo TX-SR501 Receiver Logo
13 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
