Question about Culligan Sediment Water Filter Heavy Duty
Red valve has a slow leek - Culligan Sediment Water Filter Heavy Duty
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
If you are referring to the pressure relief button then this can be repaired. Turn off the water on inlet and outlet, take the housing off and remove filter. There is a small washer under relief button that can be replaced. Unscrew the button from inside of head to repair.
RJ
Posted on May 14, 2011
Hi gas is leeking from where the red bung goes on the top of the valve when the knob is depressed to ignite? jim
It sounds like the seal is gone and not holding. Turn the gas off to the unit and call a qualified service man to replace the valve. These valves are non-repairable and can only be replaced. Be ready for the price of a new valve, they are not cheap. Are you sure the leak is coming from underside of knob? Sometimes the pilot tubing line will start leaking at the fitting on the gas control valve and if so it will leak when the knob is pushed in.
Mar 18, 2018 | Heating & Cooling
My dewalt 2 gal air compressor model D55141, when on hisses inside the pump housing. Sounds like a leek. Some pressure builds.
More than likely is leek. Must get to it to look at connections and air line to find out If slow probably would hear it. But loud you will find it. Tighten connections if it's there, other wise replace line
Jan 05, 2018 | Dewalt Air Tools & Compressors
Fuel leek from the carbs overflow
Hi, Neil and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
Good luck and have nice a day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 02, 2015 | Motorcycles
My 91 honda prelude is leeking oil and its smokes when hot but cant figure out where its leeking from
easiest way is to get the dye and poor it into your engine. Then with the dye light you will be able to track the source. On those years the most likely spot was the intake manifold gasket and valve cover gasket. You also could have a blown head gasket that only blew on a oil intake side, doesnt mean that you would over heat
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_677dced97ad9bddf
Mar 03, 2015 | Honda Cars & Trucks
Pressure guage and needle vaule leeks
Replace guage and needle valve.
May 16, 2014 | Plumbing
2003 lincoln towncar I have to add a can of R134a to the a.c. system every 2-3 days. How do I find the this slow leak
get r134 with dye leek detector add it to system look for dye where it leeks if this was helpful please leave good feed back
Jun 28, 2013 | Cars & Trucks
2004 6.0 stop after stop sign found IGR Valve bad under tubo put new one in from dealer and still no start. Need help thanks
looks like stc fiting ic leaking at the oil injection pump
igr??? probably ipr valve same area removed cover
on right side vale cover removed icp sesor get adapter
and apply 100psi plus of air presure with igniton power
at ipr valve and look or listen for leek before removing air
power out ignition feed or it will spray back unless leek is
fairly larged
Jan 18, 2011 | 2004 Ford F350
Combi boiler wont re-pressurize when i turn the little valve under boiler it just seems to run and run and the pressure gauge dosent go up at all? there are no leeks. but a minute a go it went right up to...
the little valve is a one way type. this means the pressure should only flow one way. it's a good chance that the valve body is allowing the pressure to back flow. i would replace that valve. this should take care of it. please rate this thanks
Aug 29, 2008 | Water Heaters
Check to see if your pressure relief valve is partially open. This is about all it could be unless you are losing flame under the boiler vessel.
Thanks
Zerko
Aug 29, 2008 | Heating & Cooling
Culligan Sediment Water Filter Heavy Duty Logo
460 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
