Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
I have an electric trimmer plus 132r. Some times it works and some times it doesn't. When it doesn't and I play with the cord then the trimmer plus works. What do you recommend I do to fix the problem?
  • 279 Answers
If you can get it going by "playing" with the cord, that is the problem. Either get a new cord or strip the one you have and find the break, repair it and go to work! Good luck...Lee
Posted on Aug 08, 2010
7.5 amp/14-inch electric wee trimmer. Why has it failed?
Check you battery no matter how new it is with a volt ohm meter.
Oct 10, 2015 | Garden
My less than a year old electric trimmer began smoking after about an hour or use. I realize now I should have sharpened and oiled the blades prior to use. My question is: Is this unit now damaged (smoke,...
Hi Anon, there is a strong possibility that you have burnt the motor out. Before use you said yourself that you should have oiled it. Try and do this now but be CAREFUL and dont be surprised if it doesn't work
Aug 03, 2015 | Electric Garden
Does the easy starter assembly include the spring.Part no.310022001
My experiance with these is that they are a throw away item as people hate working on them. Do yourself a favour and get a husky. My reason for this is reliabilty. I have owned a 524l for 6 months and reliable as ive also owned a 132r for 30 years that did the rings but for 30 years with minimal maintanance i think that speaks for itself. Dont muck around with this cheap chinnese rubbish. It will cost you. Both now and in the long run
May 06, 2015 | Homelite Mighty Lite Lawn Trimmer
Clutch permanently on
If the clutch is permanently engaged then the clutch spring is weak or broken
Jan 01, 2013 | Husqvarna Garden
Emergency power cut now won't start
you cut cord have open circuit.your electrical cord has three wires neutral wire white wire black wires hot wire and bare wire for ground. if you cut either neutral wire or hot black wire in the electrical cord no power can flow to trimmer motor if you cut wire need to fix wire to get trimmer work again.
Dec 24, 2012 | Cars & Trucks
How to restring 132r trimmer
Get a gater head for your trimmer. It has 4 easy to replace strings, that when broke off you can make up a new set with a pair of side cutters, or just replace 1,2, or 3, I put one on my homelite and it's the best thing i've seen since sliced bread.
Mar 30, 2010 | Ryobi Garden
How do I change string on my Ryobi TrimmerPlus 132r? I am unable to get the cartage off to replace the string. I have aligned the arrows but it will not pull apart
Send me $45.99 and I will give you the information in three easy lessons. But wait! I will even throw in an easy dvd and a twitter showing. All for the easy one time payment of $45.99.
Aug 01, 2009 | Ryobi Garden
Weed eater
Hi
check the following link
The idea is the same for all trimmers
http://www.youtube.com/watch?v=WFu66Q6J62Q
good luck
Jul 19, 2009 | Ryobi 15" Electric Factory Reconditioned...
My Ryobi 132r don't work
THE MOTOR HAS PUSHED BACK INTO THE INTERNAL HOUSING. YOU CAN DISASSEMBLE THE HOUSING AND FORCE THE ELECTRIC MOTOR TO IT ORIGINAL SET UP BUT OVER TIME THE MOTOR WILL KEEP MOVING BACK. THE COOLING FAN WILL BEGIN TO GRIND ON THE HOUSING. THE PLASTIC, HOLDING THE MOTOR IN PLACE,WILL BREAK DOWN AND PUSH AWAY FROM THE ATTACHMENTS.
Sep 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
136 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
