Question about Broan-NuTone Allure II QS230SS Kitchen Hood
How do i remove the lights to replace????? - Broan-NuTone Allure II QS230SS Kitchen Hood
  • 8,197 Answers
May I get the make and model # to help you more.
Posted on Aug 08, 2010
Marker light replacement
you have to remove head light housing to replace marker light.look in owners manual in glove compartment it will show you how to remove head light housing to replace head light or marker bulb.
Jun 19, 2013 | Cars & Trucks
Replacing headlight
Inspect/Replace There can be slight variations in procedure from one model to another when replacing headlights. For instance, on some models the turn signal light assembly must be removed before the headlight can be replaced. Overall, however, the procedure does not differ much from the following typical instructions.
Make sure the replacement bulb is the same type and part number as the one that is being replaced.
f19-22.jpg Comparing the old and ther replacement headlamps. To Replace:
  • Remove the headlight bezel retaining screws. Remove the bezel. If necessary, disconnect the turn signal lamp wires.
  • Remove the retaining ring screws from one or both lights.
  • Remove the retaining rings.
  • Remove the light from the housing. Disconnect the wiring connector from the back of the light.
  • Push the wiring connector onto the prongs at the rear of the new light.
  • Place the new light in the headlight housing. Position it so the embossed number in the light lens is on the top.
  • Place the retaining ring over the light and install the retaining ring screws. Tighten them slightly.
  • Check the aim of the headlight and adjust it, if necessary.
  • Install the headlight bezel. Secure it with the retaining screws.
  • Connect the turn signal lamp wiring (if it was disconnected).
Jan 02, 2011 | 2002 Chevrolet TrailBlazer
Replace headlight
according to autozone.com under their 'Product & How To' procedures,
To Replace:
Dec 19, 2010 | 2002 Porsche Boxster
Replacing volvo 240 head light unit
To Replace:
Nov 10, 2010 | 1982 Volvo 240 Series
How do you replace xeon headlight low beam bulb
Nov 05, 2010 | 2005 Volvo S80
How do i replace the headlight on a 2008 outlook
Oct 31, 2010 | 2008 Saturn Outlook
How do I replace a left hand side low beam light on a Subaru Tribeca 2008
Oct 28, 2010 | 2008 Subaru B9 Tribeca
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
Jun 26, 2009 | GE Microwave Ovens
Replace the tail light bulbs in 2004 infiniti g 35 coup
tail light bulbs are replaced by removing the tail light housings. The housings are accessed by removing the nuts, the nuts are secured behind the inner trunk liner inside the trunk. Remove fasteners holding liner in place, remove 3 nuts for each housing(i believe it's 3 nuts if my memory serves me right), remove housing and replace bulbs
Jan 13, 2009 | 2004 Infiniti G35 Sport Coupe
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
112 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Marvin
Marvin
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
