Question about Sport & Outdoor - Others
We have a 1994 28 ft. ford jamboree motor home and had the propane filled the other day but when i turn on the gas switch it just continues to beep and pump but not getting the propane. There is a little key hole next to the switch that a friend said was to release pressure so that it will start filling but i dont know how to use it or what to use to do it. I was not given any kind of key that fits it when i purchased it. Can you please tell me how to work it so i can get the propane working. Thank you, Barbara Taylor
ginko
  • 19396 Answers
SOURCE: The machine gets stuck mid cycle
If the inlet valve and the pump work correctly then it must be a problem with the timer control.
Here you find a replacement for the timer control assembly, just enter the model number.
Same here, free diagrams, and you can buy parts, enter the model number.
Here instead you find repairing tips : What is wrong with your Washing Machine?.
Regards
Posted on Oct 11, 2008
stormbrewin
  • 426 Answers
SOURCE: 2000 mazda MX-5 1.8l
Have you checked that you have power to the coil on cranking?You may also want to check wether you have a good strong spark at the spark plug.It could be an ignition module breaking down.If you have no power to the coil you may need to change the ignition relay.Its close to the battery.
Posted on Oct 26, 2008
SOURCE: refusing to start cycle. key symbol flashing and a beep
Hol d the start key down for around 5 secs and it will remove the lock. Release the button and press start and it will work again.
Posted on Jan 03, 2009
  • 11 Answers
SOURCE: 1997 blazer fuel pump problem.....
ya the fuel pump wont pump with the lines off but the pump is going bad they will work and wont work
Posted on Mar 06, 2009
  • 21 Answers
SOURCE: 1990 pontiac j6000 wont start
Crank position sensor bad?
Are you sure the fuel pump is working? Might be the sending unit in the fuel pump that is bad. Clogged lines, clogged fuel injectors, clogged fuel filter, all things that could be checked.
Posted on Apr 07, 2009
I need a gas tank trim cover for a 1979 dodge Fleetwood jamboree y24 its the plastic square around gas tank fill port
Fixya is unable to suggest sources for a 1979 Dodge Fleetwood Jamboree y24 gas tank trim cover.
Apr 13, 2018 | Dodge Cars & Trucks
1988 Ford Jamboree no power to the water pump & hot water heater
There are repair videos on YouTube for the 1988 Ford Jamboree C-Class Motor Home. I'm not sure what the problem is that you are having. Is it no power in the wiring in the unit to run the water pump and water heater?
Also at www.rvbasics.com there is a listing of several repair manuals and other helps.
Aug 22, 2017 | RVs
1999 fleetwood jamboree motor home
There could be a turn off at the stove or on the gas line to the stove
Feb 03, 2012 | Grilling
8/11-1997 motor home dometic rm2310 3-way frig: 2 days ago i got a nice blue flame for the gas operation.now, i can't get gas to flow to the burner to ignite the burner. that is when the gas is turned on...
Few items to check first.
Inspect propane regulator.
#1 Is the RV on level ground?
#2 Purge the air pocket in the line. Turn on all you stove heads. Let it burn for 3 minutes to eliminate air pocket on propane line.
#3 Inspect for leak marking on the outside panel.
Aug 11, 2010 | Refrigerators
A friend gave me one kitchenaid dryer , i don't understand. canI use eletric power and propane, or only propane. I don't have the propane pipes conections, can you please help me understand it?
Your propane dryer only dries with propanr. The electrical cord is for the motor that turns the dryer and for the controls. If you don't have gas piped into your house then your gas dryer is useless. Either get an electric dryer or pipe gas into the house. If you have Natural gas in your home, then you need to get a conversion kit to make your dryer run on Natural gas.
Jun 17, 2010 | KitchenAid KHEV01RSS Dryer
Propane switch not working properly.2005 EXpedition Motor Home
turn off the heater, turn off the tank, turn on the heater, count to ten slowly, turn off the heater again, turn on the tank, turn on the heater. This MAY work due to the saftey features in modern propane systems, if not you only lost some time and I apologize
Jan 08, 2018 | Square Xintex S-1A 2" Bezel Propane...
My Home propane tank was empty, I just had it filled, but when I go to turn on the heat, a flame icon comes up. I noticed on the heater it has an on/off switch for the automatic pilot light. I am not sure...
Make sure all switches are on and open. It may take a few attempts to get gas to the burners so you may have to reset the furnace by either the Emergency switch or circuit breaker. If it takes longer than 3 tries, you may have a gas regulator problem and will need to call your gas company for repair. The regulator belongs to the gas company so they shouldn't charge you to repair or replace.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Jan 04, 2010 | Coleman Propane Forced Air Heater...
Out of propane in my truck how do i fill it up
Is the engine in your 1989 Ford F-250 truck fitted to run on LP (propane) gas, or are you referring to the R-12 freon refrigerant in the Air Conditioning system? If you mean the refrigerant, production of R-12 (dichlorodifluoromethane) was phased out several years ago, and if you can find a old can of R-12, whoever has one will charge you an arm and a leg for it. You can get a kit to convert the air conditioner over to R-134a, but due to the risk of injury, this job is better left to a professional. There are a few R-12 replacement products that don't require a licensed technician, such as "Freeze 12" (http://www.freeze12.com). To add this you just need a tap and hose kit to connect to the low pressure line into the compressor and fill with the refrigerant. The can will get very cold and any leaking gas could cause skin damage from freezing, and accidentally connecting to the high pressure line will cause the can to blow up, so be careful. If you need propane, just call a propane company that fills home tanks to come out and refill your truck tank.
Apr 03, 2009 | 1989 Ford F 250
Sport & Outdoor - Others Logo
69 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
