Question about Infinity Reference 1300a Car Audio Amplifier
I have an infinity 1300a amp. I have had this amp for about a year or so with no problems. I've been away for 5 months for school and when i came back i immediately turned my car on and listened to them. They worked great, but the next day when i tried them the protect light comes on and off pulsing the subs in and out. I have checked all wires and everything seems to be in good condition. any ideas?
4 Suggested Answers
  • 14 Answers
SOURCE: Thunping coming from subs when car is turned off.
2 things to try, one. run your RCAs on the opposite side of the car as the positive wire. if you still hear the thumping try changing your RCAs. if you still hear the thumping, try a different anp or head unit. if you still hear the thumping, your subs are blown. best of luck
Posted on May 11, 2009
tc3gs400
  • 14 Answers
SOURCE: 1300a, no sound, protect light
if u have the amp bridged un bridge it. chack an see wat the ohms are on the subs an make sure the amp is stable to carry the ohm load..if u have 4ohm subs one sub per channel then u shud be fine that wud make the amp see 4ohms but if u have dual voice coil subs it cud be the configuration of the subs..here's a link on how to wire subs hope this help..http://mobile.jlaudio.com/support_pages.php?page_id=145
Posted on Jan 12, 2010
caroldon
  • 17130 Answers
SOURCE: Infinity 1300a car amp won't turn off...
The possible area is definitely in the stanby switching circuit. A damage to the relay drive has made the power to be continuously on without the remote switch. You can have two solutions, one you can ignore the fault for the time being and connect a second relay fromt the system to trigger the relay and subsequently switch the amplifier main power. Or you must open the set and look in the remote switching area for a jammed relay, a faulty transistor drive or activation of the bias to the relay drive by a faulty component. Check this out with a good multimeter and you will solve the issue. I hope my advice helps. Good day
Posted on Jul 23, 2010
I have a 2005 Mitsubishi Eclipse with the Infinity high end stock radio installed, which has a 200 watt amp under the seats. The head unit does does not have direct speaker outputs. The head is connected...
I am going to refer you to the live help
at crutcfield.com audio
They can give you ideas on compatible equipment and designs that will achieve your desires without the OBVIOUS overlad/mismatch.
Your search for comparison returned these articles
Free factory (usa market) wiring diagrams
BBB Industries Premium Alternators Starters Power Steering Products
Mar 11, 2017 | Infinity BASSLINK Car Subwoofer
Jul 22, 2010 | Infinity Reference 1300a Car Audio...
My protect light wont turn off and my ground is good and all other wires are good also!
is your sub/speakers ok? unplug and probe the speakers to see if any of them are grounding out... or your amp my be shot...
Apr 30, 2010 | Infinity Reference 1300a Car Audio...
Protect light keeps comin on
MAKE SURE THE GROUND IS GOOD ON BODY OF CAR BOTH UNDER THE HOOD AND WHERE YOUR AMP IS GROUNDED
Apr 18, 2010 | Infinity Reference 1300a Car Audio...
All wires are hooked up but no lights come on, is
Hi Wex,
Wires being hooked up is fine. With no lights coming on the question becomes one of power.
Ground needs to be grounded.
+12VDC should have +12VDC
Remote should also have +12VDC when the stereo is on.
Check these with a volt meter. Negative lead on the ground terminal, Positive on +12V then Remote.
Both combinations should read +12VDC.
Next check the fuses if any that your amp has. Make sure they aren't blown.
Comment back if this doesn't point you in the right direction.
Mike
Dec 08, 2009 | Infinity Car Audio & Video
05 infinity fx dashboard bubbling
Good news!! Infiniti is extending warranties on the dash bubbling problem -> http://www.infinitiscene.com/forum/showthread.php?t=8697
Sep 07, 2009 | 2004 Infiniti FX35
I have an Infinity 530a 5 channel amp. new
May be the problem is on the sound you are using is not a 5 channel coded sound or check in the menu´s of the amp if the rear channel´s have sufficient db output, check the connections, check if you amp. is not working only as simple stereo (menus also)
Hope this helps
Jun 24, 2009 | Infinity Car Audio & Video
May 08, 2009 | Infinity Reference 1300a Car Audio...
Infinity Reference Amps stay illuminated
Hello shaymus_hoos,
No, it isn't supposed to work that way. Although amps are usually wired with the positive directly to the vehicle battery, they aren't supposed to turn on unless power is supplied on the remote wire.
The problem is most likely in either the head unit or one of the amps. And if not corrected, the amps will sooner or later, completely drain the battery.
First see if it works properly with just one amp connected. Remove the remote turn-on from 1 amp at a time and test with the vehicle and head unit off and then on. If the problem is still there with just one amp connected, either the head unit is at fault or the remote wire is picking up 12V somewhere along it's path to the amps. Make sure you have it connected to the right wire on the Kenwood. Every Kenwood I've seen uses blue/white for the remote wire.
If both amps work OK separately, one of the amps is causing the problem. You may be able to correct it by using a relay to electrically separate the turn-on signal for each amp. You'll need a "double-throw, single-throw" type of relay. Here's a link to the Basic Car Audio Electronics web site that details the connections http://www.bcae1.com/. Connect the remote wire coming from the head unit to one side of the relay coil and ground the other side. Bring 12V positive from an "accessory" lead that is hot only when the ignition is in either the "ON" or "ACCESSORY" positions to one side of both sets of relay contacts (it doesn't matter which side). Connect the other sides of the relay contacts, one to each amp turn-on connector.
Hope this helps.
Apr 22, 2009 | Infinity Reference 7541a Car Audio...
Infinity Reference 1300a Car Audio Amplifier Logo
53 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
