Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover u8173-900 think motor is bad but how to disassemble
How to disassemble or test motor
    President:
  • 1,673 Answers
Is this a Savvy? If so your problem may be in the handle switch asm or one of the circuit boards. The switch is really a problem, but they have come out a hopefully a better one. If it is the motor, take it aprt, you can check it with an ohm-meter to see if you have reading or if it shows an open. If it isn't froze up, and has an electrical burn smell, then the field of the motor is bad.
Posted on Jun 17, 2008
We have a Hoover WindTtunnel, Model U6435-920, which shuts off after just a few minutes of vacuuming. We've been told that it has a heat sensor that is malfunctioning, but that it can be bypassed. Is...
What you have is a bad thermal fuse. The fuse is located on a motor wire inside the motor compartment,( part # 28382093, msrp $ 6.59). A good deal of disassembly is required to access this part. Bypassing is NOT recommended.
Aug 16, 2011 | Hoover Windtunnel Supreme U5280-900...
Have a Hoover model S3670 and the beater brush no longer spins. Have checked the beater belt and it is good, did find out that the light bulb in the unit was bad. Any suggestions on how to test the motor...
I usually test the motor with a cord with alligator clips on the wires, and attach them to the black and white wires on the motor ( remove the belt first ). A very common problem with this model was a short circuit developing in the short cord that runs from the nozzle motor into the swivel neck. This is probably where the problem lies. Replacing the cord is best left to someone with experience.
Apr 19, 2011 | Hoover Vacuums
I have a Hoover Mach 2.7 Windtunnel that shut off during use and wouldn't turn back on. Was doing kitchen floor and running fine. Though a breaker tripped but didn't...what could it be?
It sounds like your thermal reset switch inside of your Hoover may have gone bad. When a vacuum cleaner doesn't turn on it, it's either caused by one of four things.
  1. Electrical Short in your Cord.
  2. Plug has gone bad.
  3. Motor of your vacuum is faulty
  4. The On / Off Switch has gone bad, and/or your Thermal Reset Switch has gone bad
Since this happened while you were vacuuming, I would guess that this is either your electrical plug that's shorted out, or that your thermal reset switch has shorted out. Your model Hoover was built with a protection system that is supposed to automatically shut down your machine if it senses any excessive heat. This mechanism is controlled by a Thermal reset switch which is located in motor compartment. This part is notoroious for failing, even when there's no overheating that's occured.
Before you disassemble the entire machine to check this part though, I would try testing the On / Off switch in your machine, as well as testing the electrical cord, which will also let you know if your plug has gone bad.
Here's a link to a solution I've done here on FixYa explaining how to check the On / Off switch;
http://www.fixya.com/support/r4530569-replace_off_switch_hoover_windtunnel
While you have this apart, you can use the same electrical tester to test your cord. Simply put one end of the test into the terminal from the switch, and the other end of the test on one of the metal prongs that plugs into the wall. See if you have continuity here, if not, switch to the other prong of the plug and see if this helps.
If not continuity, this means your plug, or your cord has failed. If you do have continuity, this means that it's either the On / off switch, or the Thermal Reset Switch that's gone bad.
Here's a link to the solution that I've done on here showing how to replace the Thermal Reset Switch on your vacuum cleaner:
http://www.fixya.com/support/r4999778-replace_thermal_overload_switch_hoover
If you'd like some more help diagnosing this vacuum, please feel free to just use the comment field on the bottom of this page. I'm always happy to help you do some more advanced diagnosing, or answer any questions you may have.
If you found this solution helpful, please be so kind and rate this repair helpful, or leave feedback for me. This is greatly appreciated by the FixYa community. Thanks so much,
Chris Jones
GoVacuum.com
Jan 10, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
The Rotary Brushes do not spin.
that model has a direct drive brushroll motor and transmission. the brushroll motor is most likely bad test it with a continuity tester if it tests open or high resistance than its bad
Jan 03, 2010 | Hoover U8147-900 WindTunnel V2 Bagless...
The motor won't run. There was interupted running
What model#? Plus check to see if their is a reset switch, sometimes on hoover the switches do go bad, but if the unit is new could be still under warranty
Nov 23, 2009 | Hoover Vacuums
Vacuum won't turn on when plugged in and switch is turned on
The easy answer to this problem is you need a new cord. Any fit all 20 to 35 foot two wire cord will work. However, you will need to take disassemble the almost the entire vacuum to test the current cord to see if it is bad. There are a lot of pieces to take off to get to the inside of the vacuum where the cord enters from the back. You could also have a bad motor.
Nov 18, 2009 | Hoover U6311-930 Power Drive Bagged...
The steam vac stopped working while in use and
If the cleaner will not turn on at all, you could have one of several problems:
(1) Bad foot switch
(2) Bad power cord, or
(3) Motor failure.
The unit would need disassembled and tested with a continuity meter to determine the part that failed.
Oct 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Was using the SteamVac and it just stopped doing
Bad news! The humming is the pump so it is still good, but that means either the ac to dc converter is bad or the motor went up. The good news, neither would be your fault.
Apr 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
69 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
