Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
When I turn the machine on it says I need service error 105
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now error code 105 is called COMMS. ERROR TIME-OUT.This means the display module has detected an error in the communications between the display module and the motor controller.There are 3 reasons why this error code appears, the 1st is a faulty display module, the 2nd is a faulty motor controller and the 3rd is a faulty rotor sensor.The way this fault is tracked down is to 1st change the display module and if that does not rectify the fault then change the motor controller and if the fault is still present then change the rotor sensor.Sorry for the bad news on this fault and unfortunately you need the components to find the fault.I have double checked to see if there is a way to check the components easily and I have not been able to find one.Please reply on how you would like to proceed and I can help you as much as I can.
Posted on Aug 08, 2010
Aquqsmart Error 105
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Jan 26, 2012 | Fisher and Paykel Washing Machines
My Fisher and Paykel IW810AU has stopped mid wash full of water and just beeps constantly and flashes message I need Service Fault 105. Have turned it on and off at the wall with no change. Please help.
Hi, the faults 105 is reported when the Display Module detects an error in the communications between the Display Module and the Motor Control Module.
The primary source of the problem is the Pump and you have to measure resistance of pump. If resistance is less than 33 ohms, replace pump.
May 16, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Error e-00004-105 para copiadora canon ir 5570
try this solution: enter service mode by pressing *(additional function) then2 and 8 together and then again * select copier on screen>function>clear>error>ok. turn off the machine and re-start.
Jan 18, 2011 | Canon imageRUNNER 5000 Copier
What is code 105
Error code 105 means you have a Comms. Error Time out. This means there is a communications error between the display module and the motor controller.Now have you replaced a part in the machine recently?Just looked in my manual and it also says, to rectify this fault you might need to replace the rotor sensor on the motor.Please reply and tell me if the machine became faulty or a part was changed for another fault and then Error 105 started appearing in the display.Hope to hear from you soon.
Jun 04, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I have a canon 105 image runner with an error code of e000019-0000
Your waste toner bottle is full. On the right hand side of the machine, at the very back and to the bottom you will se a panel about 12 -14 inches high and 5 inches wide. This is held in by 1 or 2 screws - remove this cover and you will se the waste toner bottle - empty it carefully. Also, you may need to go into service mode to reset the waste toner count - but this counter only alerts the user to get the botle changed. To enter service mode press the 'head' key the 2 and 8 together, then the head key again quickly. Then select 'counter' from the top right tab - then select MISC i think - look for WASTE TNR and select it and press the 'C' button from the keypad. This will reset the count and you will see on the right what the count is currently set to. It may be in one of the other 2 options : DRBL 1 or DRBL 2. Once you've done this turn the machine of then on again.
Dec 13, 2009 | Canon imageRUNNER 105 Copier
Ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Aug 05, 2009 | Canon imageRUNNER 105 Copier
Error code 105 for casio te-2200
Hi.
We can check the memory allocation.
Turn key to program mode.
5 SUBTOTAL SUBTOTAL (must press subtotal twice).
This will print memory allocation.
Look down the printout and tell me what figures are listed under file numbers 16 and 40.
Mark
Jan 04, 2009 | Casio Parts Cash Register PC Desktop
My canon read error e000 105
go into service mode -function-clear-error- take machine off -un plug from wall -reconnect- turn machine
Dec 05, 2008 | Canon CLC 1120 Color Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
Washing Machines Logo
835 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
