Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer back wall covered with :snow' Model tfx20sa
  • GE Master
  • 8,220 Answers
The heater element or defrost thermostat has probably gone bad. Remove the service panel and look for icefreezer back wall covered with - 8faffd3.jpgSee the heater? Looks like it is bad. Attached to it is a defrost thermodisc. When the defrost thermostat (terminator) 7953294.jpg gets to 50f it shuts off power to the heater. So check those. If both turn out to be ok then you probably have a bad adc board. Manuals are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 08, 2010
Refigerator and freezer all of the sudden don't seem to keep cold enough
The back wall of your freezer covered with snow? If it is I would suggest you replace the heater and a thermistor - Heater: WR51X10101 Thermistor: WR55X10025. If no snow then it is probably the main pcb: WR55X10656
Mar 24, 2013 | GE GSH22JFT Side by Side Refrigerator
Alarm is going off every 2 hours indicating freezer temperature is high. We can't turn off alarm, button is not working. We have to turn off the breaker but it continues to happen every 2 hours. We...
you have a defrost or system issue open freezer drawer snow on back wall you have a defrost problem not too costly
no snow on back wall and you can hear fan running in freezer most likley a low side system leak
viking warranty on sealed system 6 years full 12 years parts
also unrelated you fridge should have hinge recall done if not done yet this repair is covered by viking
Nov 13, 2017 | Viking DFBB363 Bottom Freezer Refrigerator
Back wall of frezzer covered with snow, removed cover, coils frozen over with ice. have to de-frost freezer every 3-4 wks. Model#: GSL22JFTA BS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE GSS25JFM Side by Side Refrigerator
The back wall in the frizer cover with "snow".What is the problem?I open cover -ice and snow.I onplug fridge for mealt .What is next step?I I think defrosting is not workng.What to do?
heatman101
Aug 31, 2010 | GE Refrigerators
"snow" in the freezer
YOU HAVE A DEFROST PROBLEM IF THE SNOW IS ON THE BACK WALL. ISSUES WOULSD BE --TIMER, DEFROST THERMOSTAT. OR DEFROST HEATER. IF THE SNOW IS SOME WHERE ELSE YOU HAVE A PROBLEM WITH A DOOR SEAL.
Nov 03, 2009 | Refrigerators
I have a kenmore refridgerator side by side. The freezer is beginning to have snow buildup (it is a self defrost) the refridgerator side is not cold
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Could you find a model number like 321.256489 for example then I can find the parts to look for. Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
GE TFX20SA back wall of freezer freezing (snow like more than ice) we took the fridge apart about a month ago and blew out and let everything behind the back panel melt as it was frozen solid, it then...
CLICK HERE for an expanded view of your freezer section.
Can you see the evaporator fan moving when it is plugged in?
Otherwise your defrost timer has failed.
#257 in THIS diagram
CLICK HERE to see the part.
CLICK HERE for testimonials about installing the defrost timer yourself.
Thanks for using FixYa - a VERY HELPFUL rating is appreciated for answering your FREE question.
Jul 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung side by side
Check for snow on the back wall of the freezer compartment, Air to cool the refrigerator is supplied from the freezer section. If the coil is frozen over the air circulation becomes retarded and the refrigerator suffers. Snow on the back wall indicates a defrost problem.
May 15, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
528 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
