Question about Protron PD-758LP
I NEED A NEW BPD-H758 BATTERY PAC. - Protron PD-758LP
2 Suggested Answers
SOURCE: need to replace battery or obtain battery charger
i have one ill sell you for cheap if you can pay via paypal we are both safe i can ship it tommorow eric 253-861-7874 666gooty@gmail.com $40 shipped?
Posted on Feb 20, 2011
I have a 96 six pac truck camper need a wire digram
Have you tried search engines for the brand name to see if the manufacturer is still around?
Jul 03, 2017 | RVs
NEED wiring diagram to battery PAC for my Pride Pep Pal MM-222
Any users guide can be obtained from the manufacturer, there may be a fee for this. Or you may be able to download via Adobe Reader for future reference.
Feb 24, 2015 | Pride Health & Beauty
How do I fix Service Engine Error 181.514. INK Sense BPD Prine Error.
Have you removed the plastic covering the ink jets on a new cartridge?
Feb 21, 2015 | Lexmark OfficeEdge Pro 5500T Multifunction...
Sony instructions
Visit the Sony website. They should have a free PDF of the instructions.
Dec 29, 2013 | Audio Players & Recorders
What is ford radio code serial number is M049501
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Oct 19, 2012 | PAC Audio Pac Ms-frd1 Ford Sync Radio...
Need to replace battery or obtain battery charger for BPD-H758
Dec 05, 2010 | Protron Avion DP-200 DVD Player
Need a new rechargeable battery pac for my dvd player where can i purchase one for a initial DMI-830
hmmm i have a charger for that i have the same dvd player you can have it if you wan't! =)
Dec 30, 2009 | Initial IDM-830 Portable DVD Player with...
Need to replace oil pan
If yo ucan see all the bolts on the bottom of the pan, it will be as easy as changing your oil. Make sure you get a torque wrench for the install though so you don't strip the bolts out, and just follow the directions with the gasket.
Fig. 1: Exploded view of the oil pan and related components for the 1990-94 1.6L engine-2.2L engine is similar
Fig. 2: Exploded view of the oil pan and related components for the 1.8L engine
Make sure all old sealer is removed from the bolts prior to installation. Installing a bolt coated with old sealer could result in cracking of the bolt holes.
  1. On 1990-94 323 1.6L (B6E) and 1994 Protege 1.8L (BPD) engines, install the integrated stiffener to the engine block and transaxle. Tighten the bolts to 38 ft. lbs. (52 Nm).
  2. 1990-94 Protege 1.8L (BPE) and 1994 MX3 1.8L (BPD) engines, install the transverse member. Tighten the bolts to 93 ft. lbs. (1 Nm).
  3. Install the front exhaust pipe bracket, if equipped. Install the front exhaust pipe, using new gaskets. Tighten the exhaust manifold flange nuts to 34 ft. lbs. (46 Nm).
  4. Install the oil pan drain plug using a new gasket. Tighten the drain plug to 30 ft. lbs. (41 Nm).
  5. Install the engine undercover and lower the vehicle.
  6. Fill the engine with the proper type and quantity of oil.
  7. Connect the negative battery cable. Start the engine and bring to normal operating temperature. Check for leaks.
Hope helped with this (remember rated this help). Good luck.
Nov 18, 2009 | 1990 Mazda MX-6
Check engine light
oil pressure too low...it must remain above 23.2 psi for the multi displacement system to work...it could be any thing from low or incorrect oil to a powertrain controller..you may need the dealerships help
Oct 13, 2008 | 2007 Dodge Ram 1500 Quad Cab Sport
Protron PD-758LP Logo
391 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
