Question about Craftsman Garden
Runs for a short time and then stops,changed plug,air filter,gas filter,changed oil.
  • 51 Answers
Check for bad fuel cap (needs to vent) make sure theres no cloggs in fuel lines or in gas tank where hose connects if all is good could have bad ignition coil ,will loose spark when gets hot then returns when cools off. when shuts off emediatly check for spark hope this helps
Posted on Aug 08, 2010
Toro Mower wont stay running
The main reason why a mower starts up and then cuts off after a short period of time is because of poor air flow to the carburetor and is most likely a blockage somewhere.
First you should try this. Remove gas cap and filter then place a really thick rag over the top of the carb where the filter was and either blow into the gas tank or wrap a rag around a tapered air chuck and then place the air chuck in the gas tank (with rag fitting snug around chuck) blast it a few times and listen for bubbling, if it's bubbles then you have removed the blockage..
Take the carb off of the mower and clean the carb / jets with a thin piece of wire.
Be sure to clean the gas tank completely and the fuel line.
Check the oil level, some mowers have a low-level oil shut off.
Change the plug out with one thst is reccomended for your engine.
I wouldn't reccomend running the mower without the filter, that causes dirt and grass debri to enter the carb, fuel line and tank.
This should fix the problem, if it don't you should find a lawn mower repair service.
I hope this helps.
May 11, 2013 | Garden
My dewalt air compressor with honda gx160 5.5 engine starts runs for 2 secs then dies. then wont start for several pulls. after a minute it will start but then dies again. Ive changed plug, gas cleaned...
Control your OIL level in the honda engine ? take of (beware) for only a short moment your oil alert sensor control to know if the level is correct to reset the sensor and if the engine is running for a short time good connect it again on the working engine to reset. if the level was not correct. Control the fuel hose tank filter , change sparkplug control spark on color and a measure on the switch off connector for some dirth or connection lines or other problems that will connect to massa.
Feb 17, 2018 | Air Tools & Compressors
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Engine oil appears to be discharging through the air breather. Came on all of the sudden and seems to foul the breather within a short period of time. Rode about 20 miles and stopped within half an hour...
Check your oil level . If it is too high smell the oil to see if it is fouled with gas. If your carb needle sticks the carb may over flow filling the engine. When the engine is too full the breather blows the oil and gas into the air box. Another way to get gas in the oil is if the fuel petcock malfunctions and pours gas into the intake manifold. If the diaphragm of a vacuum petcock gets a hole in it , the engine may flood with gas. The gas flows into motor and past the rings. If you look under the engine in front of the rear wheel you may see a tube with a plug in it. Place a pan under the tube and pull the plug. It is a pollution tube for emptying the crud out of the bottom of the air box. Some Honda's used to fill there engines with gas randomly. If it happened you just changed the oil & air filter, and kept on driving. It just happened for no logical reason. So check your petcock and carbs for problems, change your oil and air filter, and always turn your petcock off when not riding.
Aug 29, 2010 | kawasaki VN 2000 Classic LT Motorcycles
I have a Karcher 3000 model G3060 OH WITH hONDA G190
It may be due to some water getting into the engine. I would change the gas and change the oil.
Sep 10, 2009 | Karcher G3025OH Pressure Washer
Honda 2000i generator runs but cuts out after a short while...
Hate to state the obvious, but is the gas cap vent set to on while you are running it? Also, next time it starts to run poorly, loosen the cas cap. If it runs fine, replace the cap.
Jun 03, 2009 | Electronics - Others
Chain saw run s for a short time and stops
The engine is unable to draw adequate fuel from the tank on a continuous basis, the filter may be clogged or there is an air leak in the fuel line between the fuel tank and the carburetor.
May 26, 2009 | Poulan Garden
Will not start
Check if fuel or spark problem,..all engines need both to run...use starting fluid in air intake ,..if it runs very shortly-fuel pmp?,,ck for spark at spark plug,work your way back..also ck timing belt-intact? Kev-MN
Nov 30, 2008 | 2000 Ford Ranger SuperCab
Garden Logo
199 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
