My Rheem RCBA3765AS17 Air conditioning unit is leaking water again from the left corner of the unit under the drain pan. I just had this fixed a month ago and cleaned the reusable filter. It is now covered with slimey black stuff! How do I get that filter clean again? I ran water forcefully through it, but that's not good enough. Is there anything else I can do myself before calling a professional again?
ranger25
  • 72 Answers
SOURCE: Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Posted on Jan 27, 2008
  • 4 Answers
SOURCE: kelvinator 90plus 60,000 furnace
the air flow you feel coming out of the vents is good on heat but not when the ac is running?
Posted on Aug 14, 2008
bobicehouse
  • 1524 Answers
SOURCE: Wall ac unit keeps freezing up inside.
Do not run it on maximum cool and fan on low. Freezes up all the time this way.
Posted on May 01, 2009
  • 252 Answers
SOURCE: A/C drain pan not draining.
The drain must have one and only one trap in it. A trap is where the pipe goes up then back down so that water is kept in a section of the pipe - will stop the air from blowing thru the drain and not letting the water drain - may not sound right but it is! I've seen this many times! Drain traps are not understood at all by the HVAC industry.
Posted on May 12, 2009
stamx
  • 9 Answers
SOURCE: leaking soleus air conditioner
must look www.stamx.com.br
Posted on Jul 06, 2009
My 5200 wall air conditions works fine but leaking water on lower left corner down my wall inside my house. Already cleared outside drain hole and is dripping but can't reach or see the inner drainage...
The outer drain hole is the only one that needed to be cleared. But, keep and eye on it, as there may be some floating debris in the drip pan. You said the unit is angled enough at the rear. So, I'm assume you have at least 1/4" to 1/2" downward tilt at the rear of the unit. If that's the case, for now, that's about all you can do. Unless you have a Wet/Dry Shop Vac. In which case you could **** the water out of the drip pan after removing the front panel of the unit. If you attempt this, be sure the Master ON/OFF switch on the unit is OFF and the unit is unplugged.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Kenmore Single Room Air Conditioner
Air conditioner leaked a lot of fluid that looked like water after being on all night. Do you think this is an easy fix, or what do you think is wrong with it? Thanks
All air conditioning units have built in drains. When the drain is clogged the water fills the drip pain and spills out. An easy fix is to open you unit and just wipe the drains. If you cannot find the drain find where the water is coming from and trace the water to the source. The other possibility is that the unit has a dehumidifier that is not properly sealed and it is leaking the water it collects if so find the dehumidifier (usually labeled) and pull the cover off clean the seal and put cover back on (may snap into place) and see what happens the next day.
Aug 21, 2011 | DeLonghi PACA110 Portable Air Conditioner
Leaking inside. Fedders A3X05F2A-J Unit is sloped away from house. Have sprayed coils. Doesn't seem to be drain hole at back of unit
Mellisia, the problem very well may be, that the drain pan hole under the unit, on the outside may be clogged. When that happens, water backs up and leaks out the front of the unit.The drain hole should be near one of the corners of the drain pan. And with Fedders, it may be on the edge/lip of the drain pan. The clog, may appear to be part of the drain pan and that's why you haven't noticed it.
Inspect the drain pan closely. If you can't find it. You can create one, by CAREFULLY drilling a hole at one of the corners of the drain pan. It doesn't have to be a large hole 1/8" to 1/4" should do.Be sure the unit is OFF and unplugged from the wall, before attempting this. Also, once the drill bit penetrates the drain pan STOP. You don''t want the drill bit to pierce the coils on the back of the unit.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | Fedders A3X05F2A Air Conditioner
2006 hummer h3 has a leak on passenger side under the dash during a rain storm
My 06 was leaking during rain also. It turned out to be the sunroof. There are two drain tubes in the front of the sunroof that run the water down the corners to the ground and two drain tubes that drain water out the back corners. The water would seep around the glass, which is expected, but both of the tubes on the front of mine were plugged, and the water would overflow behind the dash and fill my floorboards. If my H3 was leaning to the left during a storm then the drivers side would be full of water. If leaning right, then the passenger side. I had to open sunroof and blow compressed air into the drain holes to clear them, but be careful, too much air will separate tubes from sunroof and then you will have to remove the inside paneling around sunroof to get to tubes and reconnect. You may only have one side plugged. you can test it by opening sunroof and pour a little water in the small catch pan in the front of the sunroof and see if it drains as expected (to the ground under the firewall on left AND right side). You can see the holes in each corner of catch pan to drain the water. Plug one with your finger, then the other to find the plugged side. Good luck!! Hope this helps!!
Mar 01, 2010 | 2009 Hummer H3
Air Handler leaking
First make sure unit is level. Drain pan may be dirty. On the rheem or Ruud unit the back of the pan gets stopped up. Ithas small holes that let the water by and they get stopped up. Now even though your drain is clean you may have a stopped up dain pan. Check this > These are problems you can take care of your self. Open up the top panel of your unit and you can look down on the drain pan. Check for dirt and stoppage near the outlet of the drain pan. You amy also have a cracked drain pan but I doubt it. Rus
Jul 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Water leaking from top of Rheem unit.
Have you checked your drain sometimes after a long winter they can become blocked causing the drain pan to overflow
May 15, 2009 | Heating & Cooling
Leaking refrigerator
that is where the drain pan is located. it seems that the drain pan is overflowing which should not happen.
kindly check the condenser fan located at the back near the compressor. it should be the one blowing warm air at the drain pan to heat the water to evaporate.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Hotpoint HSS25GFP Side by Side...
We purchased a Whirlpool portable air conditioner in 2005 from Best Buy. Near the end of last summer the air conditioner started leaking water. We started using it again this season and it is still...
Check to see if the drain is blocked by particles/debris of any type. Also make sure that the unit is level--as level as possible. I have my Whirlpool Portable AC in 4 inch bed risers so I can drain it really easily. I slip under a small low rise pan and drain it every two days or so when it is running. Mine leaked when I tried to incline it backwards to make it drain faster. As soon as I leveled the unit the leak stopped and water again came out the hose. These units must be kept level to prevent leaks so now I always do that.
Jun 09, 2008 | Whirlpool Heating & Cooling
Heating & Cooling Logo
437 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
