Welcome to FixYa.
Based on your description, "Oven won't light/heat. Broiler does still work" the hot surface ignitor for the bake burner is likely the problem.
Here's what you can try to varify if it's indeed the ignitor...if you're mechanically inclined.
**Turn off the breaker or unplug the range and turn off the gas to the appliance before attempting any service...safety first**
if the boiler has the same ignitor ( some do some don't ) one could swape the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you have a diagnosis and can purchase another.
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case.
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number 12400035, That is the most common ignitor and is for Maytag, but built by "Norton" for gas oven`s.
I would still double check with your model number with the part`s professional`s.
Hope that help`s. Let me know if I can assist you further and good luck.
Thank`s for visiting "fixya" for your repair needs.
macmarkus :)
