Question about Sylvania LC320SS8 32 in. LCD Television
Power light blinks. Then goes back to standby. What is up?
  • 11,361 Answers
The power supply may be sensing short circuits in the power supply or in the backlight inverter board so it goes into shutdown mode. You need to do troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 08, 2010
4 Suggested Answers
SOURCE: Does not turn on.
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
Posted on Nov 04, 2007
SOURCE: my emerson tv standby light is on the power light flashes twice
I have this problem too with my 32 inch Digital LCD TV.
Posted on Dec 05, 2008
SOURCE: 37FD9954/17
hi, i have read somewhere that you need to replace both 100u / 25 caps aswell.
the info came from a user on here called PaleFace but i cannot find the original post now and i have the same problem with my tv.
Posted on Dec 31, 2008
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
I replaced the main board in my sony Kdl-32S300. When turn on power, the back light flashes 3 times then goes into standby mode after which the standby light flashes 12 times in sequence. What could be...
B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Have you set the output voltage correctly?
Mar 24, 2011 | Sony KDL-32S3000 32 in. LCD Television
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Stuck in standby
Sorry about that. When the tv goes bad like not turning on, the green light will blink, and goes right back to red standby light while the dtv letters will briefly show on the lower right of the tv screen, then go back to blank screen. The tv will need to be taken to an authorized service center for repair. Common causes are a bad inverter/power supply, power control board, or circuit board.
May 16, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Onkyo tx-sr500; power goes out; standby light blinks
Remove all Wires form speakers
Power on
Push Video1 + StandBy /On
appears Clear on display
Dec 22, 2008 | Onkyo TX-SR501 Receiver
No powering up
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
Dec 10, 2007 | Sony KP-53XBR200 53" Rear Projection...
Green standby/power light bilnks and pic goes out
you have defective power supply! at the hot side section!
Oct 08, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
No Picture, Sound Fine
Hey John, How many times does the light blink? No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open). Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. One blink - not used for the self-diagnosis Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some newer models of Sony TV sets, this code means that T8005 is defective on the D board. Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. I suggest you do a hard reset. Unplug the power cord for 4 hours. Then plug it back in and check it. If it works, great. It not, cost of repair for this is usually around $150 - $250 plus the house call.
Jun 26, 2007 | Sony KV-27S36 27" TV
Sylvania LC320SS8 32 in. LCD Television Logo
189 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
