Question about Sony STR-DE475 Receiver
Is this receiver capable of speaker signal output to "A pair" AND "B pair" AND subwoofer AND center channel simultaneously? How do I program that? Can this receiver be used as a pre-amp for switching only?
    Brigadier General:
  • 8,546 Answers
According to the manual, which you should have:
1st question: No "A" and "B" choice, just one set of Front speakers. Center speaker, yes. It requires a self-amplified subwoofer.
2nd question: In the manual. Select Speaker Sizes, presence, distances and other parameters. Run Test Tone for relative volume of each.
3rd question: Yes, for stereo material only. It has no multichannel Line Level pre-outs.
Posted on Aug 09, 2010
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
Nov 19, 2015 | Kenwood VR-606 Receiver
Very week sound
Definitely need more info - such as type of amplifier or receiver, how many speakers you are running, whether the subwoofer is powered or not.
As a simple test procedure: Disconnect all speakers and plug in a pair of headphones. Get a strong audio signal? Good, move on. No signal or week signal, you have an amplifier issue before the audio even gets to the speakers.
Next: Disconnect all speakers, turn the volume down, and connect one speaker to the left output channel. Slowly increase the volume. If that works, do the same on the right channel. Everything OK? You're putting out enough gain on both channels. Sometimes one channel goes bad. You can still listen to your sound in mono moder, or drive two speakers from the single working output. Not stereo, but dual mono. Move on.
Connect left and right speakers but not the subwoofer. Repeat the test. Whatever is left is probably the problem. If the subwoofer is powered, check the power supply or incoming voltage. If the other speakers are driven off the subwoofer or powered from there, that's likely the problem.
Jul 31, 2015 | Audio Players & Recorders
Hello I have another question but this is containing my back up surround sound receiver til I can find a Sony receiver that I like. Ok this receiver is a AV receiver model ht-r420 onkyo surround sound...
Subwoofer sockets
The HTR-420 has only a single subwoofer output. It is the socket on the lower left corner. The other subwoofer socket is part of the multi-channel input.
Because of the age of the 420, it comes from a time when optical and coax connections were not so common and DVD players had 6x phono/RCA sockets to send out the surround signal in analogue format. The multichannel input is for sending a signal in to the amp, and not for getting a signal out. That's why the sub doesn't get a signal from that socket. Use the proper subwoofer out. That's what it is there for.
Speakers A+B
The 420 was designed to run Speakers A+B together if required. However, you must observe the minimum impedance loading if you connect up two sets of front speakers and run them simultaneously.
The minimum Impedance for each set of front speakers is 8 Ohms. If you're recycling old surround speakers from a Home-Theater-in-a-Box system, or the speakers have no labels for impedance on the backs then you can be fairly sure they are not 8 Ohm. That could be the problem.
Sep 09, 2014 | Audio Players & Recorders
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
How do I hook up speakers?
If you are referring to 5.1 surround you would have to have 5 speakers plus one powered subwoofer. The front left and right as well as your center channel to the majority of the sound reproduction with the rear channel being there for intricate sounds and background noise. The subwoofer will be a preamp output from your receiver. That signal will then get amplified by your subwoofers power amp. Generally subwoofers are tucked away in a corner while the other 5 speakers form a box around your viewing area.
Feb 11, 2010 | Pioneer VSX-453 Receiver
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Feb 08, 2010 | Jamo SUB 200 Subwoofer
I'm using an old Yamaha stereo receiver off my Panasonic Plasma to run a pair of E660's, can I just use the Speaker ''B'' on the receiver to run the center channel? (E660CEN)
I do not believe that you can. If you use the "b" channel for the center channel, the "a" channel will not process the left and right channels simultaneously. It is either or, not both at the same time. It may be possible to run your E660's directly off the TV output adjusting the volume from the TV, while running the center channel through the Yamaha receiver and adjusting the volume for the center channel from the receiver.I hope this helps.
Oct 26, 2009 | Audio Players & Recorders
Panasonic av control receiver sa-he200
On any 5.1 system without 2 zone capabilities when you press speaker "B" the receiver uses the rear channel amplifiers to send signal to the remote speakers. As a result the receiver cannot output signal to both the rears and the remotes at the same time.
Feb 26, 2009 | Panasonic Audio Players & Recorders
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
I need to set up 4 pair of speakers, two zones. all ceiling mounted.
Okay! all ceiling mounted speakers. I don't know about 4 pair of speakers.Here is the load down:
First pair of ceiling speakers would be left and right front from speaker A or Main output behind your receiver.
Second ONE,but a pair would be connect to the center channel output as your center speaker.
Another pair would be connect to the surround sound left and right(NOT surround BACK left/right.)
Now,you have 5 channel setup at this point,you still need to purchase a power subwoofer to the SUB PRE-OUTPUT behind your Denon receiver.
For Zone two,you would need to connect your other pair of speakers to surround BACK left and right output.
Go to your Denon MENU button,depending on which model you have,some of them will have an on-screen display feature(you would need to have a composite video cable connect from the video output behind your receiver to the TV video input in order to use the on screen menu.)If not,you would have to it view on the front panel of the A/V receiver.
You need to read the detail on how to setup the video and audio as well as distance and DB for the receiver through the menu button.
I will be frank with you,if you are an amateur,Denon is NOT easy to be setup on the first time.
solutiondoct
Nov 06, 2008 | Denon Audio Players & Recorders
Sony STR-DE475 Receiver Logo
182 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
