Question about Apple iPod touch
Why does my ipod say connect to itunes - Apple iPod touch
    Problem Solver:
  • 8 Answers
Connect to iTunes means that your iPod Touch is in Recovery mode.
Simply plug your iPod Touch into your computer, laptop, or netbook and iTunes will tell you to restore to the latest firmware. Press "OK" and it'll download the latest firmware. In this case "iOS4".
Once it's done you'll have to sync all your music, games, apps ect what you have lost or choose a Back-Up.
Hope this helps :)
Posted on Aug 08, 2010
My ipod is disabled and says connect to itunes but it also says itunes could not... so what do i do?
Step 1:
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly unlock your iPod Touch.
Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore." When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore." After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration. iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Mar 01, 2013 | Apple iPod touch Original
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
My ipod wont show up on the bar when i plug it in the itunes
How to connect to itunes
Connect the iPod to any one of the computer's USB ports via an Apple USB cable.
Open iTunes on the computer.
Click the name of the connected iPod, which is located underneath the "Devices" menu in the left iTunes column.
Click the "Summary" tab that is found at the top of iTunes.
Click inside of the "Manually manage music and videos" box positioned in the middle of iTunes.
Click the "Apply" button that's positioned near the bottom of iTunes. You will now be able to safely connect the iPod to any iTunes.
hope this helps
http://download.cnet.com/apple-itunes/3000-2141_4-10235268.html
Sep 15, 2012 | Apple iPod touch
I formated my Apple iPod accidentally . Now its functioning like a mass storage device. It does't play songs (by itself), but it plays through Autorun when I connect it to the Computer... Please send the...
First, try to use iTunes. Open iTunes and connect your iPod. If it is recognized, copy some songs, then eject it and try if it plays them.
Otherwise, follow the instructions on this link http://support.apple.com/kb/HT1238
Feb 28, 2011 | Apple iPod shuffle MP3 Player
IPOD is diabled cant conect to itunes
Hi, can really say much about your problem now. I think i can help out.
First might not know if you connected it properly with the iTunes .
All i can do is togive you the right steps to connect iPod touch with iTunes. Hope that will help.
Below are the steps to use iPod with iTunes.
How to Use iTunes With an iPod
Using iTunes with an iPod is not difficult since iTunes are designed for iPods. Your iPod can use iTunes as well as other MP3 files with ease. Below is a list of steps to help you use iTunes with an iPod.
Instructions
Turn on your computer and open your iTunes program.
Now connect your iPod with your FireWire. You should have received a compatible cord for connecting your computer to your iPod when you purchased it. Connect the cord to your iPod and then connect it to a USB port on your computer.
Use the "Set Up Assistant" to enter in a name for your iPod and select "Automatic Update" option if you want to put all of your songs on to your iPod. "Automatic Update" will allow you to update your iPod easily every time you add songs to iTunes.
Click on "Register" your iPod and enter in your product information on the iTunes Web site.
Click on "Done," which is located at the bottom of the box, and you will receive a message saying that your iPod is being updated.
When the update is finished, click on the "Eject iPod" button on the bottom of the page. You will be instructed to remove the iPod when it is safe to do so.
Unplug the FireWire from your computer first and then disconnect the wire from your iPod carefully.
Tips & Warnings
Choose "Manual" if you do not want all of your iTunes songs on your iPod. If you use
manual you can select which songs you want to transfer.
Your iPod will automatically update after linking for the first time.
In "Automatic Update" mode, you cannot edit your songs on your iPod.
Make sure you have enough memory on your iPod.
Have a nice day.
Feb 16, 2011 | Apple iPod touch
My ipod touch 4th generation says -ipod is disabled connect to itunes- tried that and itunes wouldnt open unless unlocked my ipod and i cant. I tried restoring it and itunes said ipod can not be restored...
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
Jan 13, 2011 | Apple iPod touch
Ipod is disabled connect to itunes
Go on to itunes and plug your mp3 in to your computer
and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
Aug 19, 2009 | Apple iPod touch Second Gen (8 GB,...
Ipod nano 16gb won't connect with pc(itunes).
Is your ipod nano fully charged? and your installed iTunes the latest version?
Please make sure it is charged, and the new iTunes is downloaded and installed from here please do the following steps:
Connect ipod nano to PC. Make sure iTunes is already open prior to connecting it.
If this is the first time you are connecting then your PC will automatically install Apple Mobile Device Driver.
Once installation of the driver is complete, you should see the ipod nano logo appear within iTunes very soon. and start using it.
Jul 20, 2009 | Apple iPod nano
Unusual iPod Classic connection/sync problem
Try downloading the driver for your ipod onto your computer and see if that works
Mar 26, 2009 | Apple iPod classic 6th Generation Digital...
Apple iPod touch Logo
173 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
