Question about Canon PIXMA MP130 All-In-One InkJet Printer
Mp130 waste ink absorber almost full. how to fix?
    President:
  • 1,138 Answers
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Use a reset procedure to clear the error in your printer
and start printing again
1. Turn on the printer
2. Press the MENU key
3.
Press SCAN button
4.
Press the COPY button
5. Press the SCAN button then wait until it enters the service mode.
6.
Select NVRAM ACCESS further OK
7.
Select SET ABS-M LEVEL and set value equal to zero
8.
Select SET ABS-R LEVEL (if any) and is set to zero.
9.
Turn off the printer
Do this as many times if the first attempt didn't work until it fully reset.
Posted on Aug 11, 2010
  • alalnroyston Nov 29, 2010
    Thanks, worked 1st. time.
  • pamela Jul 08, 2012
    Very clear instructions--worked the first time. Thanks!
Waste Ink absorber is full.
this msg show that you will need to reset your printer waste ink counter and replace the waste ink pad.. you can try to reset it with a resetter software here.
http://www.fix-printer.moon4ever.com/?cat=5
May 28, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Waste ink absorber is full How do i empty it
You can't empty that one, you need a shop to replace the pads which are under the printer, and they can reset the waste ink counter at the same time.
Sep 29, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Apr 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink asborber i almost full... how do I fix
I am providing you with a link that will provide you with everything you could possibly need as the owner of this printer. This link on Canon's Web site will give you access to user guides/manual, driver and software downloads, support, specs for the system and much, much more.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10442
This link will take you directly to the Support & Service tab on the Canon Pixma MP130 page.
(If not, simply click the tab labeled Support & Service).
Type "waste ink absorber" in the text box then click Search.
Click 1. ERROR LCD: WASTE INK NEAR FULL which will result in 4 solutions to this problem:
  • Ink absorber replacement options - mp130
  • Press ON/OFF switch to reset the multifunction device
  • The mp130 may require repair
Try 1 and 2 first. You must click on the solution to view the details.
This should also be helpful in the future event that you may need to download drivers or access the manual to troubleshoot/fix an issue. Drivers and Guides can be downloaded from the Drivers & Software tab.
Hope this helps! Share your experience by rating this solution.
Thanks for using Fixya!
Mar 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber near full PIXMA MP130
Take paper towel and absorb the excess ink from the tray, including  cleaning of the electricial contacts that she excess ink in tray.
Jan 16, 2009 | Canon PIXMA iP1600 Printer
My Canon Mp130 Printer waste ink absorber is full. How do I replace it ?
I hope I have fixed it. I followed the advice of 'Reverend' this morning and did some mopping up with the aid of a torch and some tissues and have made a couple of unblemished copies.Despite this the screen still says 'waste absorber nearly full' and I would like to instruct it to cease !
pe004h9127
Dec 11, 2008 | Office Equipment & Supplies
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Canon pixma MP130
ink waste absorber is almost full, what should I do?
Jan 20, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
1,233 people viewed this question
old marine
old marine
