31" tv I have my tv in my summer home. During the off season the cable channel degrades my service to save money. In April when my cable is restored to normal channels I can't get all the channels on my TV. Last year I figured it out, but can't remember what I did. I think it has something to do with the stored memory maybe. I tried auto program and unplugging the TV.
    Scholar:
  • 131 Answers
You need to make sure your cable channel are all on then reprogram tuner put it in menu make sure it is set to cable then. reprogram set
that should do it thanks Doctor video leadingedgeelectronics since 1987
Posted on Apr 27, 2008
Vertical line flashes on tv screen
Picture problems are surely among the most common technical issues experienced by home TV viewers. Such problems may manifest themselves as pixelization or frozen pictures, intermittently flashing pictures on one or more channels, static or audio degradation, or channels that are missing altogether. To address these problems, you can always contact the technical support department of your cable TV provider and have them walk you through troubleshooting steps, but it is wise to learn how to fix problems like this on your own without consulting any outside help. Doing so can save you lots of valuable time and money in the long run.
1.Reset your cable TV equipment by unplugging the power cords of any digital cable boxes/DVRs you use in the home. Count a full 30 seconds and plug the equipment back in. After allowing the device enough time to complete its boot cycle, check the picture again for any improvement. A cable box in need of a reset is by far one of the most common causes of many different picture degradations, so this is a necessary first step.
2.Check the audio/video connection cable or cables that attach your cable service equipment to your TV. Loose or malfunctioning cables are also a very common cause of picture degradation. Secure any cables that may have come loose and replace any visibly damaged cables. If you think the cables may be failing, you can temporarily test them by plugging another audio/video connection cable from the cable equipment to the TV and checking for any improvement.
3.Scan through your entire channel lineup as well as all the input channels on your TV. This will help determine the scope of the problem and how to most effectively troubleshoot the issue further. If you see the vertical lines on only one or a few cable channels, the issue is much more likely with the broadcaster or your cable provider, and you will need to report the issue to your provider. If you see the vertical lines on all channels and all video inputs, it is more likely that the TV's picture components are beginning to fail, and you will need to have the TV serviced or replaced altogether.Thanks for using FixYa, hope this will help your problem.
josie
Oct 19, 2011 | Televison & Video
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
How to set humidistat for different seasons.
Vick, depending on the season and the humidity level in your home, is what determines the setting. For example, in the winter you want to maintain at least a 40% humidity level in your home. It will feel more comfortable, the heat will feel warmer and it will help keep static electricity at bay. In the Summer, you'll want to remove as much humidity as possible, as this will make the air feel cooler. If you have ceiling fans in you home, run them Clockwise at the highest speed you can tolerate. The more wind chill you generate, the cooler the air will feel and you won't have to set your AC at a lower temperature. Thereby, saving money. In the winter, run the ceiling fans Counterclockwise on the lowest speed. This will take the heat off the ceiling, wash the walls and bring it back down.
Clockwise and Counterclockwise are determined by looking up at the fan blades. Also, reversible ceiling fans have a switch on the side (where the pull chain is located). Generally, switch-up is Counterclockwise and switch down is Clockwise.
Hope this helps you to keep your home comfortable year round.
Apr 05, 2011 | Honeywell Heating & Cooling
I lost my satellite because of money problems. I don't have cable for the same reason. My television will play dvds but I cannot get any television channels. Is there a setting I am missing, or any other...
Yes.
You will need to get an antenna(either indoor or outdoor) for OTA (over the air) receptions,
> Connect the antenna to the back of the tv.
> Go into the main menu and set the channel signal input to Air instead of Cable.
> Go to the channel auto-program menu and scan in the channels.
> Save the results.
> Watch tv.
There is something called FTA (Free to Air) which is similar to satellite tv but does not have a monthly cost. You would however need a receiver.
Mar 13, 2011 | Televison & Video
How do you hook up to the comcast digital unit to
tune your tv to channel 3 if you're coax cable, if you're using rca or component cable then tune your tv to the proper input on your tv.
Jun 26, 2009 | Apex Digital AD-1500 DVD Player
I put the wall cable to the vcr and the cable to the tv to the vcr, and i put the vcr on channel 3 and want to record channel 31, it records channel 3
you state here you put the vcr on chanel 3 but you want to record 31. put the vcr on chanel 31 to record
Aug 01, 2008 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
