Question about InFocus ScreenPlay 4805 Multimedia Projector
I have almost opaque line on the right edge (not top/bottom) it was there before i change the bulb an now it is worse.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
The light tunnel likely has collaspsed. a collasped tunnel isn't adjustable.
Posted on Aug 10, 2010
How do i change the light bulb in the reading light in a pajero
Hi What year is your Pajero? and which light? the one above rear view mirror? if it is carefully prise the plastic casing near on off switch at the edges where is slots into holder. You maybe able to see the the Opaque cover the retaining lugs, if you can pry opposite, hope this helps, Paul 'W'
Jul 15, 2014 | 2000 Mitsubishi Eclipse
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Feb 21, 2012 | Craftsman Garden
Shop vac is not pumping out water just fills the canister
The question makes perfect sense assuming we are talking about the ShopVacPumpVac. These devices are, essentially, a combination shop vac and sump pump. For those answering the question, you can see literature on these vacuum/sumps here: https://www.shopvac.com/includes/streamPDF.asp?loc=pdf&id=Shop-Vac-Pump-It-Out .
When I have experienced the loss of drainage, I have found a couple obvious problems and solutions.
First, make sure that the garden/discharge hose is not kinked at any point along the line from the vacuum to the outside. If kinked, the line will not drain.
Second, the baffle can become blocked or clogged. Take the following steps to determine if your baffle is clogged and to clear the clog:
1. Turn off and unplug the vacuum.
2. Unclip the two lid clips.
3. Lift the lid of the vacuum. When properly set up, the baffle hangs below the filter housing on an opaque hose about 1 foot in length.
4. Grasp that hose and pull firmly downward. Once removed, I take that hose and the attached baffle to an outside garden hose.
5. Pull the baffle off the opaque hose.
6. Spray water from your garden hose through the opaque hose to make sure it is clear.
7. Spray the baffle clear.
8. Lightly tap the port of the baffle, where the opaque hose has been inserted. Most of my clogs have been the result of hair balls (or worse) at this point. Just tap any blockage out and rinse.
Third, reattach the baffle to the opaque hose. Reattach the opaque hose and baffle to the motor under the filter housing. Set the vacuum top on the canister. Click the locking clamps closed.
If this doesn't result in clearing the clog and allowing it to drain, then you are in the exact spot I am right now. If I figure out this new problem, I will update further. But I have cleared this kind of clog maybe five times in the six months I've been using this new Shop Vac Sump Vac
Sep 08, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Drivers side headlight assy change, Nissan Sentra 2003, Front lens was cracked and old one became opaque instead of mirrorlike(fogged up).Is it hard to change?
Just unscrew the screws holding down the black tabs on top of the headlights and you have to gently pull the headlight out , be careful because the bottom of the headlight has a tab holding it in place (be patient might have to move it around to release the bottom tab). And do the opposite when putting the new headlights on. Even if the bottom tab breaks. the tabs on the top will old the headlight in place. Once it's changed, you'll need to re-aim the headlights...
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Oct 20, 2009 | 2003 Nissan Sentra
I have changed bulbs but still have a blurry line
the light tunnel is collapsing and needs replacing. the part is cheap.
Aug 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
I want to change the light bulb on my hoover elite 600 upright vaccum. How easy is it to do and where do I start? Thanks! Brian
It should be fairly easy.
You will need a flat-edged screwdriver to pry up the white/opaque plastic diffuser that covers the light - the bulb is in a socket underneath it.
Pry up an edge of the diffuser with the screwdriver and you should be able to see that it's held on with 4 tabs - two on the top and two on the bottom. Push the tabs in on either the top or bottom and the cover should pop out easily.
Jul 19, 2008 | Hoover Vacuums
Problem with screen
First, plug a external monitor and toggle the screen with ALT+F5 to check that the video card and drivers are OK.
If the image in the external monitor is correct you probably have a hardware problem in the LCD panel or its cabling.
You can get the replacement parts and change it yourself here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
May 19, 2008 | Acer Aspire 3610 Notebook
Black opaque line or bar
if its is viewable when off then yes its water or oil.between the screens.these screen don't normally come off from the front.
they have to be access from the rear.
could be big job.
only way to tell is to remove the rear cover.
Apr 13, 2008 | Hitachi 51F500 51" Rear Projection...
Red and Green Lines in TV
The optics block has failed and it will have to be replaced. Contact Sony for an auth. service center in your area as the optics block in this unit has a 2 year mnfg. warranty.
Feb 16, 2008 | Sony KDF-E42A10 42 in. LCD Television
InFocus ScreenPlay 4805 Multimedia Projector Logo
60 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
