Question about Onkyo TX-DS939 Receiver
Onkyo TX-DS939 I just got tricked into buying a 2nd hand Onkyo TX-DS939 which doesn't work... The situation is like no matter which speaker output I hooked it up to, I can barely hear the music when it's at the highest volume, with my ears at the speakers. Would you happen to know what might be wrong with it?
I have to ask the obvoius, did you get the manual, have you used the onscreen menu to set up the speakers, you can calibrate the speaker levels on the TV screen if you use the S video or RCA vidoe connection .have you turned off tape monitor?
Posted on Jun 28, 2008
Can the speakers surround sound work if the optical out is not red?
Yes.
There are several other methods for your surround sound channels to operate without your optical connection.
Jan 01, 2011 | Onkyo TX-DS939 Receiver
Problem with onkyo tx 919 unit
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Jan 01, 2009 | Onkyo TX-DS939 Receiver
GETTINF OVER HEAT
Onkyos are notorious for running a bit warm - though if yours is excessively warm, double-check the impedance of, and wiring -to- your drivers.
Nov 13, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
ONKYO TX-DS939 (sound and heat/fan issues)
This sounds like the amp is seeing too small an impedence load. In other words, the amp is expecting to see an 8ohm load and is being presented a 4 or 2 ohm load. This will force the amp to work really hard and generate excessive heat. Does the amp generate sound at all? ever? If not, then you probable have a situation with high frequency oscuillations that you can not hear. This means that the amp is sending out a lot of power to the speakers that the crossovers are shunting to ground. Without seeing the output of the amp with a scope, I can not confirm this. This is not a problem that will be solved remotely. Bring the unit to a shop and request that the output be examined using a scope to check the waveforms. I suspect that a bad feedback look internally is causing the generation of the high frequency signals.
Keep us posted.
Dan
Oct 29, 2008 | Onkyo TX-DS939 Receiver
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-DS939 optical selection problem help!
That coaxial, opt-1 and opt-2 are available only if they are not selected to some other channel. So you have to check if opt-2 is selected to Video-1,2,3,4,5,6,7,CD or DAT. Change that to Analog and then opt-2 is free to another device.
Mar 24, 2008 | Onkyo TX-DS939 Receiver
Need to buy the jumper plug
What do you mean by a jumper plug. Are you referring to the preamp jumper plugs?
Sep 01, 2007 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939 Receiver Logo
278 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
