Question about Olympus Stylus 410 / ? 410 Digital Camera
Flash will not charge. Just flashing red lighting bolt.
I have the exact same problem :(
Posted on Aug 15, 2010
3 Suggested Answers
SOURCE: POLAROID A801 FLASH PROBLEM
asdfjalkdsjflasjkflj
Posted on Apr 04, 2008
SOURCE: CASIO EXP600 Flash problem
Hi, I sent my camera to the dealer...thanks anyway, Sevendata
Posted on Apr 12, 2008
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
I have a Olympus FE-100 everything works except the flash. I have tried everything. The lightening bolt and red light flashes all the time. Change modes nothing happens. mHelp.
hi
your camera has flash circuit defective. the red light flashed mean it is trying to charge flash capacitor in its circuitry. it might has flash pcb defective or just fuse brown. you can bring to local repair shop and they would charge around $35 to 75 depend on what they really want to charge.
Thanks and best regard!
May 23, 2011 | Olympus Cameras
I have a Olympus FE-100. Everything works fine but it will not flash. Blinking red light. Blinking red lightening bolt. I have tried everything.
hi
blinking red light means camera is trying to charge flash circuitry. if you cancel flash mode, you can use taking picture. But if you want to repair, your local repair shop would charge around $35 to 75 depend on what they really want to charge.
May 23, 2011 | Cameras
Need instruction on how to put the flash for vivitar vivicam 8025
Repeatedly touch the lightning bolt function area to cycle through the flash modes. Lightning bolt with a letter "A" is automatic (camera decides whether flash is needed), lightning bolt is forced flash (always flashes), eyeball is red-eye reduction, lighting bolt in circle with slash through it is off (never flashes).
Aug 18, 2010 | Vivitar ViviCam 3915 Digital Camera
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Won't take picture
If the lightning bolt continues flashing and never stops there is a failure in the flash sub-system. Try selecting the no-flash setting, if the camera fires normally at this point then your problem is definitely in the flash system. It is hard to say what the failure is beyond that. The problem is the camera will not take the picture until the flash is charged and ready to fire - the flashing lightning bolt indicates that it is charging the flash. The fact that it just keeps flashing indicates that the flash is never becoming ready. This repair could cost $68 to $125 plus parts to fix, although an evaluation would be necessary to identify the problem.
Jun 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Kodak Easyshare Z760 orange light flashing
The flash does not charge separate from the rest of the camera. Try cleaning the flash sensor on the front of the camera or the flash led may be bad.
Secondly, this light functions as a flash sensor which is trying to tell you that you need to use a flash although you may have the flash manually turned off. looks like a bolt of lightning with a circle/slash through it.
May 09, 2007 | Kodak EasyShare Z760 Digital Camera
Canon PowerShot SD550
yes, the flash of your camera is not charging. needs repair.
Nov 03, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Olympus Stylus 410 / ? 410 Digital Camera Logo
109 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
