Question about GE DVLR223 Dryers
I have a DVLR223EE1WW GE Dryer. Was working perfectly until today. Dryer was in use, we opened door to check to see if clothes dry, closed door, hit power button and would not start. Power is coming to the dryer but it will not turn on. Any suggestions?
    President:
  • 3,074 Answers
Bypass the door switch
Posted on Aug 08, 2010
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
I have a GE Model WSM2700 WSM2780 Spacemaker Laundry stacked washer/dryer combination which is about 8 years old. It worked perfectly until the dryer no longer would turn on. I opened up the unit and...
i had something similar, did the cleaning and double checked to make sure all the wiring was hooked up and not frayed. i then "jiggled" (technical term) the dryer door button and some sand came out. it has been working ever since.
Apr 14, 2011 | GE WSM2780DWW Unitized Spacemaker Washer...
I have a GE dryer that won't dry our clothes. It heats up, but water is all over the inside door and the lint that comes out of the hose in the back is wet! The outside of the dryer (the top in...
It really sounds like your washing machine is not spinning the clothes out enough. Have they been wetter than usual lately? The dryer could just be struggling to keep up with the heavier / wetter load as there is no reason for it to create moisture on it's own.
Oct 06, 2010 | GE Dryers
GE model WHDVH626FWW Front load washer won't run, can't open door
your drain pump is likely clogged,and is equipped with a clean out port. remove lower cover by 3 phillips screws on bottom front. you see the drain pump up front to the right. If there is a lot of water left in machine then have bucket/pan avail and plenty of towels. wet dry shop vac helps. you can open door and remove clothes from here. reach up on right side to where the latch is on inside (you have to go by feel) and find small round pull tab on bottom of latch/lock asm, and pull down, this will unlock door. carefull of water level when opening door.
to fix problem, unscrew cap on pump asm. water will pour out, and a tray will slide out with debris clogging pump. look inside housing for remaining ****. using finger check impeller area on right..
reassemble. machine should work perfect now. Pump is designed to be cleaned out and will not void warranty. newer machines have access port cut in panel for this clean out area.
Apr 26, 2009 | GE Washing Machines
Dryer won't turn on for 2nd load
A couple of things is to make sure you have 110v at the recepticle, if you do then it's with in the dryer. It could be the door switch wont close, thermal over load won't reset in your motor(if it got hot enough to open, you said it had been in use) , broken belt switch if your dryer has one, or even the thermal fuse (in series with L-1) opened up. Ohm out the door switch in the closed position, it should read 0 ohms, Same with the thermal fuse, should read 0 ohms, not an open read.Good Luck..MJE
Mar 25, 2009 | Dryers
My GE Dryer model DWSR483EA1ww will not stop & doesn't dry quick
first thing you should do is check the flow of your vent, a clogged vent can cause all your problems check it outside while the unit is running you should get really good flow compare it to the flow of the dryer with the vent hose off the dryer completly. they should be fairly close or just run it with out the vent hooked up to the vent if you have an electric but not with a gas dryer
Mar 09, 2009 | GE DWSR483EBWW Electric Dryer
My ge wont dry clothes it takes 2 hours
Check the exhaust duct. It's best to have a short run and no obstructions. It's also possible that a heating element could have been damaged in the move.
Dec 31, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Jun 14, 2008 | Kenmore 67082 Electric Dryer
GE DVLR223 Dryers Logo
271 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
