Question about Poulan 42Inch High Lift Lawn Mower Blade (2 Pack)
Engine shut off when release the clutch on weedeater band model 130-504 18.5hp twin2 42"cut automatic riding mower
    Problem Solver:
  • 7 Answers
Loss of power = possible blown head gasket. Do a compression test. You can buy compression tester for cheap now days or get a loaner from some of the automotive parts stores.
Posted on May 03, 2012
  • 51 Answers
With mower off remove belt from engine pully make sure every thing turns freely blade spindles,pullys if all turns reinstall belt on engine check seat switch,break switch.for safty reasons pto will not operate unless some one is in seat ground curcuit runs through seat and break switches hope this helps
Posted on Aug 08, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My sears craftsman riding mower will crank just fine, but as soon as I try to either put it in gear and release the clutch to go forward or backward, it shuts off. It also shuts off when I attempt to...
Many folks have found that a defective relay in this mower to be the cause of the "stall when i take my foot off the clutch" issue. The relay is connected to the safety switches which turn the mower off when no one is in the seat, etc.
Aug 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a new husqvarna 20hp, 48"cut,automatic,powered by Koler. engine dies everytime I try to rerlease the clutch.
Check the seat switch. It (the mower) is designed to shutdown if the clutch is released without the operator being on the machine. It may need to be adjusted.
Best regards, --W/D--
Aug 08, 2009 | Husqvarna Garden
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Engine dies off once brake/clutch is released
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Jan 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42Inch High Lift Lawn Mower Blade (2 Pack) Logo
164 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
