Unit runs but will not cool. Fanruns fine but when turn dial to cool the compressor kicks in for about a second or two the kicks out. Fan works on cool but it will not produce cool air at any temp setting. I have cleaned filter and removed cometic facing and vacuumed the coil face. It was pretty dirty but after all that still would not cool, Unit is installed in a RV and power is provided from house. Gen4erator is also available for power. Unit is difficult to remove from RV and space to get at it is limited to front of unit. Is the problem worth trying to fix/ repair?
    President:
  • 3,773 Answers
You may need to install a hardstart kit if you can get to the compressor.
go to your nearest appliance parts store to get the part and the instructions are usually on it. If not ask the parts man.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 08, 2010
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Jan 06, 2018 | Kenmore 73055 Air Conditioner
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
Compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Jun 29, 2009 | Coleman Mach 15 Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
