Question about Amana Refrigerators
I have an Amana side by side refrigerator, model SXD22S2E. The ice maker does not work. It freezes Ice but it does not dump the ice into the ice bucket. -- Suggestions?
    President:
  • 3,773 Answers
Check temp of freezer (10 degrees or better)
If it is then you probably need a new icemaker.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 08, 2010
My water works on my refrigerator but my ice maker doesn't work.
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , replace the water valve ( the piece the wall water line connects to on the refrig ) . If it freezes and does not dump , replace the ice maker . Also check the rake ( rotating arm ) , to see if a small piece of ice could be blocking it , keeping it from turning . If so , the small cube could be an indication of not enough water going into the ice maker ( replace the water valve ) .
Apr 18, 2010 | Maytag MZD2669KE Side by Side Refrigerator
Ice maker dont work
Make sure by filling with water and let freeze and if the ice dumps and does not refill the your water control valve is at fault. Your model has the electronic style ice maker and replacement is in just replacing the electronic core and cub slots. I will return with part numbers and a photo. Thanks, Sea Breeze
Dec 19, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ARS2665AW side by side ice maker not filling
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
ICE MAKER NOT GET WATER
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...the temperature(it needs to be 0-4 degree F for the ice maker to start) may be defrost problem send me a note if you need info on that
Aug 24, 2009 | Amana SXD524VW Side by Side Refrigerator
ICE MAKER NOT WORKING ,MODEL #gss25lgma ww
The problem is most likely the water control valve on the rear of your refrigerator. You can test the ice maker by filling with water and let freeze. If ice dumps then the water valve must be replaced. Your model has 3 different choices of water control valves. If the ice maker does nothing but freeze the water and not cycle or dump the ice then I would say the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | GE Refrigerators
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
NO ICE IN MY BOTTOMFREEZER AMANA REFRIGERATOR
If we both are on the correct subject then it is possible the water control valve on back of refrigerator is not working. If ice tray is dry then fill with water from a cup and let freeze. If the ice maker dumps the ice let me know and we will go from there. Sea Breeze
Apr 26, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Dec 16, 2007 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
135 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
