Question about Vacuums
Need to dismantle a dyson dc20 power head a the turbine is tight. one screw is inaccessible unless the cover opposite the red pull out 'activator' is removed. How do you get the cover off??
I just cracked this. The cover can be prised off using a flat-blade screwdriver. There is a little slot for this. I imagine there is a proper tool for the job, because it's a bit difficult and a bit frightening, but it does come off. I couldn't do the same with the larger cover on the other side, though. My brush wasn't rotating, so I squirted as much WD40 as I dared in as many orifices as I could find, and, lo and behold, on reassembly it started working again.
Posted on Oct 01, 2010
The turbine head of my DC39 stopped working. The suction is super, took the brush out and disconnected the hose and looked into it, no blockage is visible looking. ideas?
hi russ, it's jack at dyson.
i'm sorry to hear you're having difficulty with your dc39's triggerhead floor tool. i appreciate you've already checked for a blockage, but you may want to follow the steps shown in our online support guide just to make sure there's nothing you've missed: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/dc39-check-extension-tube
if you find there's no improvement after running through these checks we're happy to help further - and if a replacement is needed, we can confirm if this is covered under your dyson warranty. you can reach our experts directly by calling on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
Jan 20, 2015 | Dyson DC39 Animal Canister Vacuum
How to I fix the stuck power cord on the Dyson DC23 Turbine Head Animal?
Hi Saule, it's Jack at Dyson.
I'm sorry to hear your DC23 Turbine Head's cord seems to be stuck. If there's an issue with the cord reel mechanism, your machine may need a repair.
We'd be happy to help you arrange this, and will also be able to confirm if this is covered under your Dyson parts and labour warranty. Please note, we would advise against trying to repair the machine yourself in case damage is caused - if your vacuum is within our warranty period, this could also void any remaining cover.
When you have a moment, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) to discuss your options with our experts.
We'll look forward to speaking with you.
Dec 20, 2014 | Dyson Zorb Mini Turbine Head, NEW Animal...
How do I get a new belt to repace a broken one in a DC23 turbine head
Hi there, it's Jack at Dyson.
The Turbine head's belt is not a part we would ask a customer to fit, and therefore it's not available as an individual component. It's part of the turbine drive mechanism, and we'd advise against attempting to dismantle this as it could result in damage to the Turbine head. If the Turbine head happened to fail within the Dyson warranty period we should normally be able to replace it, as long as it's been used and maintained according to the User guide. Out of warranty, a replacement Turbine head could be chargeable.
If you'd like some additional help or advice from our experts you're welcome to contact us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 07, 2014 | Dyson DC23 Turbinehead Canister Vacuum...
Dyson DC23 canister vacuum turbine head stops spinning. Red on/off circle does not start the brush. If we cover the rubber 'u' gasket a tad, it will start spinning again normally. Putting the cover on does...
Hi Jyn, it's Jack at Dyson.
The rotating brush bar in DC23's Turbine head is powered by the vacuum's airflow. From what you've described, it sounds like there may be a blockage somewhere in the machine that's affecting the performance.
To locate and remove any blockages, please take a look at our online Support guide and follow the steps shown on each of the pages: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/check-telescopic-wand-step-1-turbine-head
In normal use the pre-filter should be washed at least once every 3-6 months, using cold water without detergent. Even a filter that appears to be externally clean may still need a wash as fine dust particles may be contained within the filter material. The correct method is shown in the video attached. Make sure you allow the filter to dry completely for at least 24 hours before replacing it.
We would advise against attempting to modify the Turbine head in any way, as this could cause damage not covered under guarantee. If you'd like some further advice from our experts please feel free to give us a call - our contact numbers are: 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 23, 2014 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
Dyson DC23 canister vacuum turbine head attachment stops spinning.
bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
May 17, 2017 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
How do I dismantle the telescopic wand on my DC20? I've tried washing it but the smell is still present. I think it needs separated
Hi Gerardette, it's Jack at Dyson.
We would strongly advise against washing or attempting to dismantle your DC20's wand. Not only can this cause damage as it's not designed to be taken apart, but the water can actually increase any odour coming from the wand as it may not be possible to dry it effectively. Attempting any maintenance not shown in the User guide could also void any guarantee remaining on your machine.
I would encourage you to contact our experts directly for some advice - you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 19, 2014 | Dyson Vacuums
Hi how do you dismantle the head turbine for the Dyson Hoover DC80 as i need to clean it and i have no idea how to dismantle it!
There are two (or is it three) plastic screws on the underside of it. This allows it to be partially split so you can clean the area around the brush roll.
To strip it further needs a Torx T15 bit, but I don't advise doing that unless you know what you are doing and are confident about the re-assembly.
Cleaning around the brush roll area is all most people need to do with these and that is a simple matter.
Jan 18, 2011 | Dyson DC08 Cylinder Bagless Canister...
The brush does not turn but the belt seems very tight. There is also suction at the top of the hose but no suction at the brush head. I have removed ever pat that I can tell that comes off. Any...
DC07s have two drive belts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Sep 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Jan 24, 2010 | Dyson DC08 Cylinder Bagless Canister...
DC20 Turbine Head rubber part torn
The only place you might get the part is from Dyson
Thet do not let these type of parts to any trade
Feb 17, 2009 | Dyson DC08 Cylinder Bagless Canister...
Vacuums Logo
690 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
