Can you help me what the error code E000220-0001 i have a canon IR2200 copier machine. Please help.
  • sashivja Aug 08, 2010
    fault in the inverter of scanning lamp ( exposure lamp)
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
  • 64 Answers
SOURCE: Error code E000740-0003
hi the error code means tah lan card cannot be read and faulty check the harnes betwen it and the PCB if its ok change the card thanks.
Posted on May 20, 2008
Cogz
  • 1326 Answers
SOURCE: Canon iR2200 Copier
E003 is a fixing unit error code. Have you been having power problems? Is this the first time it showed up? If so you need to reset the code in service mode..
Resetting Code: Press "*" additional fun.
Then at the same time "2&8" Then the "*", then touch "Copier", "Funca", "CLR", "ERA", then "OK"... then turn the main power off then on.
Posted on Jul 10, 2008
SOURCE: canon ir6000 error codes E000061-0001..
error E061 poblem
Posted on Dec 02, 2008
  • 100 Answers
SOURCE: hi, i have 2pcs of
Sir i am a Canon trained tech. I just checked our website and my service information. I found the following. I suspect someone has been working on these machines or swapped some parts around.
Page 1 of 2
MODELS AFFECTED / SERIAL NUMBERS AFFECTED:
Digital Copiers, Including All imageRUNNER Products
SUBJECT:
Information About The New Soft Counter Circuits
GENERAL TECHNICAL INFORMATION
GENERAL:
This Technical Publication presents information about the new Soft Counter circuit that replaces the mechanical counter
used in the past. There are three (3) PCB’s associated with the new Soft Counter circuit; the Counter Memory PCB,
Main Controller PCB and the Serial Number PCB. A description of their function is provided below. Use this
document as a reference for current and future models that use the Soft Counter circuit.
Counter Memory PCB
On the latest Canon digital copiers, such as the imageRUNNER 5000, imageRUNNER 8500 and imageRUNNER 2200
series, there are no mechanical counters. Instead there is a Counter Memory PCB. This PCB is usually mounted on the
Main Controller PCB with one screw. The Counter Memory PCB is imprinted with the serial number of the machine
the first time power is turned ON and cannot be moved to another machine. Attempting to do so will generate an E246
error code. In the event of a Counter Memory PCB failure, a new one from stock (see Note 4) can be installed into the
machine. At that point the Main Controller PCB will transfer its present total count as indicated in “Counter Check” on
the control panel (recorded the last time power was turned OFF) to the new Counter Memory PCB and the total counter
will increment from that count on. Never attempt to operate a machine without the Counter Memory PCB
installed!
This may generate an E245 code, which can only be cleared by “zeroing out” the Main Controller PCB by
one of our A.P.R.F.’s (Authorized Parts Repair Facilities).
Main Controller PCB
The Main Controller PCB, aside from performing other tasks, retains the total count by means of SRAM with a battery
back up after power has been turned OFF. If, however, the Main Controller PCB has been replaced with either a new
one or a used one, it will read in and record the total count from the Counter Memory PCB retained the last time power
was turned OFF. The total count will then increment from that count on.
Note 1:
Even though the total count will be the correct value for that machine after replacing the Main Controller, the soft
counters in Service Mode will not. If a new Main Controller was used for the replacement, then all soft counters in
Service Mode (service counters in “Counter Mode”) will be zero. If, on the other hand, a used Main Controller was
used for this replacement, the soft counters previously recorded on that PCB would be shown. At that point it is
advisable to clear these values in Service Mode using Function>Clear>CNT-MCON.
All Main Controllers sent to our A.P.R.F.’s for repair will be “zeroed out” before being sent back to the dealer.
Page 2 of 2
GTI-T151
04-30-02 GT I
Note 2:
The Counter Memory PCB and the Main Controller PCB should never be replaced simultaneously!
This will
generate an E354 code and assistance from the Canon Reseller Technical Support Center Hotline will be required. If
the Main Controller is sent to one of our A.P.R.F.’s for repair, you must remove the Counter Memory PCB
before sending it out!
Failure to do so will only increase down time for your customer.
Note 3:
If the Main Controller PCB is replaced, ensure that connector J1023 is connected. If it is not, an E350 will be
generated.
Serial Number PCB
The Serial Number PCB’s main function is to identify the machine’s serial number. This PCB cannot be moved to
another machine.
Attempting to do so will generate an E355 and assistance from the Canon Reseller TechnicalError codes not listed in the Service Manual:
There are various error codes that are not listed in the Service Manual. Canon U.S.A., Inc. reserves the right to treat
these error codes as Proprietary Information. If you encounter any of the following error codes, contact your Canon
E245 E246 E247 E350 E354 E355
Note 4:
Please be advised that Canon U.S.A., Inc. treats the Counter Memory PCB and Serial Number PCB as “restricted” parts.
When a dealer orders these components they will be asked to provide the reason for their replacement, and the original
PCB will have to be returned to Canon U.S.A., Inc. for evaluation.
Posted on Jan 08, 2009
Canon ir 2202 error code e0141-0000
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR2200
Jun 19, 2015 | Canon Image Runner 2022 Copier
Ir2200. E00000-0000 what solution
This normally implies a functional issue with the machine. Try an error reset first in case the unit was turned on\off or lost power recently: To reset the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR. If that doesn't work you will need to test some components - are you a repair tech or have electronic experience if not you might want to contact a service center to avoid hurting the copier or yourself. If you do have experience take a look at page 6-10P http://diagramasde.com/diagramas/otros2/IR2200_2.PDF and Error Codes Canon iR2200 Warning!
If you are not familiar with electronics, do not attempt to repair!
There is a risk of fatal electrical shock! Instead, contact the nearest service center!
Jan 09, 2015 | Canon IR 2200 Digital Copier RECONDITIONED
ImageRUNNER 3300 All-In-One Laser Printer: PLEASE TELL ME SOLUTION FOR THE ERROR CODE OF IR22...
* 2 8 * ( service mode )
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on
If does not helps replace fixing film assy
May 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
IR2200
When I pluge my Canon IR 3300 is showing me to Turn OFF and ON the Switch in the right, if the problem did not solve, so please send solution on Email - rajkumarsingh_kushwah@yahoo.com
Apr 28, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir2200 has an error code e502/0000 what is this please
the code u r asking is a finisher code if u had installed the finisher then reconect the conector again
Mar 03, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon iR2200
press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
Jul 14, 2008 | Canon (6981A002AA) for imagerunner 2200,...
May 20, 2008 | Canon imageRUNNER 2200
E000014-0000
E000014-0000 ir 3300 canon machine solution
May 03, 2008 | Canon (6981A002AA) for imagerunner 2200,...
29 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
