Question about Hayward 100kbtu Pool Or Spa Propane Gas Heater H100idp1
Pool Heater. Hayward H100ID Starts fine and heats for about 5 minutes. Then heat stops. You can feel the blower its just cold air.
  • 640 Answers
It sounds like your pool heater is not firing. I would check several things: the burner might be blocked and clogged, the gas valve might need to be replaced, the direct spark module might be malfunctioning, or the combustion blower might be cleaned. One of these is probably the issue. A service man can repair all of these problems.
Posted on Aug 19, 2010
Hayward H100ID wont heat water
If the heater is operational, working and the top of the heater is hot, and you do hear the combustion of the gas, see flames in the burner tray area...
.... then your heater is heating the water!
If there are flames in the heater, the heater is normally doing its job. Most people are not aware of the time it takes to see a "Temperature Rise". The average temperature rise is dependent on your heater size, the ambient temperature of the time of day you would like to use your heater, the wind/breeze factor as it goes over your pool surface. Is the pool waters surface covered? etc. All of this is a factor on how quick the temperature will rise. It is possible that you will not feel warm water coming from a return fitting.
Another common mistake some pool owners make is the system is on a timer. And the desire to start the initial warming of the water starts with the flick of the heater switch and then a few hours later the pump turns off and along with it, the heater. The heater will only work, if the pump is on and circulating the water! No circulation, no heat! So if you have a timer, remove the "Off" timer pins and allow the heater to work.
Jul 11, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward h100id leaking
if water 70 or below it is condensing and the water is dripping on the flame bar and sizzling if over 70 degrees check for leak in heat exchange if that is leaking you need a new one and check chemistry
Sep 09, 2012 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I have a hayward H100ID above ground pool heater. Recently the heater is making a rattling sound and the in and out hoses are bucking or pulsating. The water is still being heated but somehting does not...
low water flow is making the heater knock, (PULSATE) clean filter or backwash, check pump and skimmer baskets and empty. if still low flow and knocking, check impeller on pool pump to make sure it isnt clogged.
Aug 30, 2011 | Hayward Pool & Spa
Heater will not light
There are several things that can cause this symptom. If you have a volt/ohm meter and call the Hayward technical support at 908-355-7995 they might be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward H Series Induced Draft Abg 100,000...
Hayward Heater Problem ''AO'' error. H400IDH
Thank you for posting your question here on Fixya.com.
It sounds as if the air activated switch the tube you mention attaches to is not working. Pull the two wires from it and connect them to simulate the switch closing. Start up the heater to see if you get ignition. If so, replace the switch.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 14, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pool heater fires up and starts heating the water outflowing into the pool, but only stays warm for 5 minutes or less then cools and stops heating
You are tripping a temp limit switch. You either have a bad switch which you can jump the wire to confirm. This is a trouble shooting technic only. Jumping the wire permantly might cause bigger problems.
Aug 17, 2009 | Hayward H Series Propane Electronic...
Hayward H250 FDP Pool heater won't stay lite
sounds like a flame sensor.remove ignitor assembly and clean with fine emory cloth or steel wool.when properly cleaned it should feel smooth for entire length of sensor
Jun 20, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward 100kbtu Pool Or Spa Propane Gas Heater H100idp1 Logo
452 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
