Question about Whirlpool Calypso GVW9959K Top Load Washer
How do I reset FL code on my Kenmore Calipso Washer? It just blinks and then beeps every 10 seconds.
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Our washing machine will not drain, and keeps bringing up "LD" error code. It keeps beeping and the timer isn't going down.
  1. residential washer displays error codes. Though designed to indicate the nature of the error, to anyone without a copy of a washer manual handy, the codes might as well be Martian cryptography. Luckily, the Manage My Life website has partnered with Kenmore and made manuals for each make and model of Kenmore washer available online. The error codes are differentiated between top and front-loading machines.
  2. FH Error Code
  3. When a front-loading Kenmore residential washer displays the "FH" error code, the machine is experiencing a water-inlet problem. A water-inlet problem is the result of the washer receiving too little water to operate. The Kenmore owner's manual suggests five home remedies for this problem: Check that the water faucets connected to the washer are turned on; that the inlet screens in the washer's connection hose are not clogged; that the hose is not kinked; and that the hose is not frozen. If none of these problems are present, turn off the washer, unplug it, plug it back in, and restart the machine.
  4. FL Error Code
  5. The "FL" error code on a top-loading Kenmore residential washer indicates that the machine has over filled. When a residential Kenmore washer is overfull, it will beep every 10 seconds. The pump will cycle on and off every 30 seconds in an attempt to rectify the problem. To stop the pump or restart the machine, either disengage and then re-engage the power source to the washer, or push the overfill reset switch. If water continues to enter the machines after the "FL" error has appeared, shut off the inlet flow faucet or the machine will overflow.
  6. F02 Error Code
  7. The "F02" error code on a front-loading Kenmore residential washer indicates that the machine is experiencing a drainage problem. Home-remedy solutions for this error code, as suggested by the Kenmore manual, are similar to those for the "FH" error code: Insure that the drainage hose is not kinked, frozen, or clogged. If none of these problems are present, check that the hose is less than 96 inches, or 8 feet, above the floor. A hose more than eight feel from the floor will not drain properly
Dec 06, 2010 | Kenmore Washing Machines
GETTING AN ERROR MESSAGE OF FL, WHAT DOES THIS MEAN?
This means that your Washer has somehow Over Filled with water and will "FL"ood if it does not drain the excess water:
It should also be beeping every 10 seconds and the pump should start to empty some water to rectify the issue.
Restart the machine machine as required or push the overfill reset switch.
To avoid flooding, you might need to temporarily shut the water supply if water continues to flow in the machine while the "FL" code is displayed.
Hope it helps let me know how you go.
Sep 28, 2010 | Kenmore Elite 21082
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calipso alarm FL WIL NOT spin water out of tub
Hi, Your washer is seeing a flooded condition. That's the bad news. The good news is that it will try to fix the condition, too. I found this info below in a troubleshooting guide:
If it occurs again, let the machine try to clear the fault before you clear it.
Best regards, --W/D--
Aug 13, 2009 | Washing Machines
Kenmore Calypso washer won't drain
Flood Condition:
Mar 20, 2009 | Kenmore Washing Machines
FL SIGN AND BEEPING, AND THE WATER WON'T DRAIN.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
This is not the same washer but all the parts are the same. Please check here for a more detailed appoarch to this problem. Click Here
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Washer displays FL code Hi Where do I find the model number for my machine. It's a Kenmore Elite Calypso Motion Top Loader? I am getting an error code of FL and need to trouble shoot problem but, I have...
I GOT THIS OFF THE MANUAL, HOPE THIS HELPS.
"FL' (Over Fill) flashes
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Nov 08, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
125 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
