Question about Danby DBC2760BLS (5 cu ft) Wine Cooler
Flashing HI Temperature Display - Danby DBC2760BLS (5 cu ft) Wine Cooler
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
G1022
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jun 13, 2013 | Miele Dishwashers
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
Flashing temperature control for freezer setting
There is no problem for that, as long as the temperature control is functioning well and it display the temperature degrees number. You vary it, hi or low and the unit still cold or freezing.
Sometimes the liquid crystal display of the electronic control module become loosen 'cause it to display in a flash manner. Unless it display "ER" it means there's something wrong with your unit. But so far it operate normally.
Thanks for asking.
Jul 04, 2011 | Refrigerators
Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
Digital temperature display are flashing for Electrolux Refigerat
Khouripablo
Did you find one solution for it problem? I have the it problem in the some refrigerator. Please send me one good answer.
berghi@windstream.net
Jul 04, 2009 | Electrolux Refrigerators
Accord HVAC/Radio/clock upper display problem
It is telling you you have an HVAC system error. Only the dealer can read the computer that controls Accord HVAC errors. Since everything works, it probably just needs to be reset. No repair needed otherwise.
Mar 26, 2009 | 2005 Honda Accord
Danby DBC2760BLS (5 cu ft) Wine Cooler Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
