Question about Boating
My 96 johnson 25hp boat motor will run for a few minutes at full speed then will die and it takes a while to get it started
    Problem Solver:
  • 11 Answers
Try changing the squeeze ball it sounds like its not passing fuel
Posted on Sep 13, 2016
  • 135 Answers
MAKE SURE THE WATER PUMP IS WORKING AND THE ENGINE IS NOT OVERHEATING THERE MAY BE A TEMP SENSOR THAT SHUTS DOWN THE IGNITION SYSTEM IF OVERHEATING CHECK FOR SPARK AT PLUGS AFTER ENGINE CUTS OFF..
IF HAS SPARK AT PLUGS AND STILL DOSEN'T RUN CHECK FUEL LINES TO CARB .
IF THATS OK SUSPECT FUEL FILTER /STRAINER /FUEL PUMP / CARB PROBLEM
HOPE THIS HELPS
Posted on Aug 08, 2010
25hp Mariner ,2stroke quite old , starts and runs at low speed beautifully ,once taken up to plane the boat one cylinder tends to cut out, and once boat has slowed down the cylinder comes back to run
Older motors have two jets in the carb. A high and low speed jet. My guess is the high speed jet is clogged, and motor is trying to run on low speed jet.
Mar 06, 2018 | Boating
Hi i have a 1984 25hp johnson with a miss, and a kick like a horse.compresson exellent new plugs and coils. thanks
Spray clean the carb(s). Put in fresh gas and oil. Run Johnson cleaner in tank of gas.
Mar 05, 2018 | Johnson Boating
Trying to get lower unit off a 88 25hp evinrude motor
www.youtube.com go there and type water pump replacement 25hp Johnson or evinrude. You can also go to
http://shop2.evinrude.com/Index.aspx?s1=gett3uheq5c0nce2mjg11d1eh0&catalog_id=0&siteid=1
Thank you, Lewis Hot Headz Marine
Sep 25, 2013 | Boating
What is the corrct fuel mix for 2005 25hp johnson
2 stroke is rated at 100 to 1... but I always run it a little more like 50 to 1. I would rather put plugs in it than burn up a motor for lack of oil......
Dec 25, 2009 | Boating
40 Hp Johnson outboard motors stalls out after a few minutes running then takes forever to start again
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Sep 17, 2009 | Boating
My 175 hp 1998 johnson (carbeurated model) is hard to start. When started it seems to run ok, but after motoring for 10 or so minutes, will just die.
Sounds to me that your carb is plugged up. I would take it apart and clean it. Also make sure your idle mixture screw is set to 1 1/2 turns out to start and adjust from there.
Aug 13, 2009 | Boating
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Jun 30, 2009 | Sport & Outdoor - Others
Motor died when I slowed down, and wouldn't crank again
Some motors have limit switches built in to kill the ignition if the motor is started at odd angles. The trim is different for speed and passenger load. The limit switches may be adjustable to eliminate that problem. Usually when you go to dock the boat will fish tail if the trim is too extreme for slow speeds.
Apr 07, 2009 | Boating
Boating Logo
326 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
