Question about Garden
Hello, I just bought a Homelite chainsaw at a yard sale with no manuel. I'm not sure what the ratio mixture for the gas. Also, When you tighten the chain is it clockwise or counter clockwise. Does it have to be running? It is a Homelite 190 Model 10778 Serial 703391944. Thanks so much for your help !
    Brigadier General:
  • 4,088 Answers
50:1 is the proper fuel to oil ratio. Make sure to premix the fuel and oil in it's own can using modern synthetic saw oil, and to shake the can thoroughly just before adding to the saw. NEVER try to adjust the chain when the engine is running! Turn the chain adjusting screw CW to tighten--be sure to loosen the cover mounting nuts so that the bar can move. When adjusting the chain, bring the chain up to the bottom of the bar, but not so tight that you can't move the chain by hand. Check bar oiling by running the tip near some cardboard at speed for several moments--it should throw off a thin line of oil. Go to: http://www.drystacked.com for 12 page article on theory and troubleshooting information for Walbro brand carburetors if you have trouble getting the saw to run correctly. Hope some of this helps!
Posted on Aug 08, 2010
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
Whats the oil to gas mixture ratio for a Homelite 42 cc chainsaw?
Use 2.6 ounces of oil per gallon of gas to give you a 50 to 1 ratio of fuel to oil.
Jun 16, 2011 | Homelite Garden
What is the gas/oil mixture for a Homelite z3300 chainsaw
Most all chainsaws older and newer pretty much run on 50:1 ratio.
May 07, 2011 | Homelite Garden
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Want to fine gas and oil mixture ratio for Homelite 16 inch 33cc
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Homelite ZR10926 16 Chain Saw
Chainsaw gas mixture ratio
An XL from that time frame recommends 32:1 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/d4b1071a456ca76c88256cd6001cc24c?OpenDocument
If my saw it would be adjusted for and operate on 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
What is th petrol and oil ratio for a homelite petrol chainsaw 33c- csp 3314
Generally you're looking at a 50:1 ratio on most chainsaws and I wouldn't see any reason the homelite should be any different. Usually it's one 2.5oz container of the oil mixture to one gallon of gasoline but check the label to be sure.
Jul 30, 2009 | Homelite Garden
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
