Question about Hitachi 43UWX10B 43" Rear Projection Television
Turn on switch wont stay on. clicking sound in back.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
The sound is the power relay clicking on and then back off since the set is in shutdown.
I would suggest you look inside on the right side (as seen from the back); there is a large metal heat sink with fins and look for any burnt or discolored resistors on THE LEFT SIDE OF THE SINK.
The most common problem in these sets is convergence and it can cause the set to shut down.
I can if you require it forward you a photo of the area to look at but:
If you want the instructions (they tell you everything you will need and exactly how to do it) let me know here by using the "add a comment" button.
There has been some trouble on this site lately where I do not see the comment; if this happens email :"support@fixya.com" and tell them you want them to contact me for the instructions.
The other option is you can also email "Lauren@fixya.com" who is the community manager here.
If the site does not notify me of your response I cannot get the FREE instructions to you.
REGARDS, SD TECH
Posted on Aug 08, 2010
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Power wont stay on
It sounds Kirby has a new model with a new type of switch go back to the shop you bought it , if you have not read the manual , a tip , 1 look how the dustbag is connected it must be good connected if not the problem is there , second the hose the hose must be connected good because if not the problem is there more options are not there for the master switch . if its controlled that the switches are god pushed in by mechanic parts of the dustbag connector or hose connector , it must run and stay on power the dustbag is the one that is the most probable connection what maybe not enough is turned to the motor housing have a stabil working on -off switch. if it not does made difference go immediatly back to the shop. with proof of purchase, you get an other new one if its a factory failure. or the powercable was accidentially bruised between a door or linger behind the powerplug and that why its faltering maybe.
Apr 21, 2015 | Kirby Vacuums
Over head lamps wont turn off
Have you checked the roller switch next to the headlamp switch? If it is rolled all the way up, then the lights will stay on all the time. Try rolling the switch back down, you should feel a "click" inside the switch then the lights will shut off. This switch also controls the brightness of you instrument cluster lights. Hope this helps.
Nov 17, 2013 | 1997 Ford F150 Regular Cab
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
How do i turn the brights on? I pull them back and it doesn't stay on
when you pull the handle back you should hear a click and the brights come on and stay on and you turn them off the same way. If you are not hearing a click sound it is likely the switch is broken and the assembly will need to be replaced. If you hear the click you may have blown headlights(on the high beam side) good luck
Aug 15, 2010 | 2000 Buick Regal
Mu 1991ford tempo fan wont turn off when i turn
does anything else stay on it sounds like you have a bad ignition switch
Dec 14, 2009 | 1991 Ford Tempo 4 Door
1999 GMCsuburban wont turn over
sounds like your starter is shorting..check your ground line and make sure no wires are crossing...you might want to also check the negative battery cable..if its not makeing a good connection to the battery or the block, youll get the same results and itll start burning out a wire..i have just recently fixed a problem similar to that on my truck.
Feb 10, 2009 | 1999 GMC Suburban
Phone switching off wont switch back on
samsung jet has just turned itself of now it wont turn on again
Jun 13, 2008 | Cell Phones
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Hitachi 43UWX10B 43" Rear Projection Television Logo
53 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
